01-31-2023, 12:03 AM | #1 |
Looking for help with my truck
Hello anyone located in the east bay area that can help me with the bed of my truck?
01-31-2023, 02:49 AM | #2 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Re: Looking for help with my truck
Just curious, but what exactly needs to be done??
01-31-2023, 04:50 PM | #3 |
The bed needs to be lined up I can't get the gap between the bed still and the cab right
01-31-2023, 07:07 PM | #4 |
It may not be all in the bed. Try measuring fron the same place on each side from the rocker to the frame. Straighten your cab if it isn't square. Then unless your frame is bent, it should gap just fine.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1971 c10 swb/1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
02-01-2023, 10:11 PM | #5 |
The Older Generation
Did you put new rubber cab bushings on it? If not, I would take a good look at them and see if they are deteriorated or split. That can also cause what you are experiencing. LockDoc
