06-16-2015, 07:48 PM | #1 |
Smooth Firewall With Vintage Air
Anyone out there smooth their firewall when they installed Vintage air?
I have done this with several other vehicles but am now working on my personal 67 and do not have the Vintage air yet. I was hoping some people could post up some pics of how they smoothed their wall and where they ran the Lines. And how they went about mounting the unit without hardware in the wall. Thanks |
06-16-2015, 08:01 PM | #2 |
Re: Smooth Firewall With Vintage Air
I'm gonna hop on here since this is a direction that I've been working through in my head also. I have the firewall shaved with the Porterbuilt panels but no Vintage Air or bulkhead connections thought out yet.
06-16-2015, 08:46 PM | #3 |
You really should look at restomodair.com that is what I have,very easy to mount with the bracketry they supply.I also have their stealth micro controls,which I mounted with a 3d printed ac panel I got from coreyjonesdesigns.com,restomodair has a serpentine setup but I will be using March.I googled hidden ac lines and got great ideas on where to mount my bulkhead.corey has a panel that will work with vintage air should you go that route,great guy to do business with.
06-16-2015, 11:19 PM | #4 | |
Posted via Mobile Device |
06-17-2015, 02:19 AM | #5 |
Laid Back
Shaved firewall.. No hoses can be seen around the firewall area.
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
06-17-2015, 10:09 AM | #6 |
06-17-2015, 01:18 PM | #7 |
I used the sure fit kit Gen IV but cut the plate supplied by them, then filled al the extra holes.
06-17-2015, 01:45 PM | #8 |
Nice
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-17-2015, 05:55 PM | #9 |
A few that might give you some ideas
06-17-2015, 06:45 PM | #10 | |
I like the direction Raleighswb is going but with my cowl speakers that may make this a little more difficult. I may just have to go through the side cowl in the hump that was the blower recess to get the same result. Keep em coming fellas All great ideas. |
06-17-2015, 06:55 PM | #11 |
That's clean.. I like where the bulkhead fittings go through...
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
06-17-2015, 07:05 PM | #12 |
http://www.restomodair.com/synister/synister-bulkheads/
This company has some slick looking bulkheads if you are gonna put bulkheads in. I like both looks.
1986 Chevy Silverado LWB (project) 1967 Chevy SBSS (future project) 2003 Chevy Tahoe (wifes daily) 2004 GMC 2500 Duramax (company truck) 1986 GMC Wrangler LWB (newly acquired beater) |
06-17-2015, 07:36 PM | #13 | |
06-17-2015, 07:41 PM | #14 |
This is actually my truck,most people that used vintage air used the universal kit so you have the choice of where the lines come out.
06-17-2015, 07:43 PM | #15 |
06-17-2015, 09:05 PM | #16 |
Dan Johnston
Here is 3-deuces...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
06-18-2015, 11:01 AM | #17 | |
06-18-2015, 12:10 PM | #18 |
Laid Back
Yes the run out of the cowl vent then behind the inner fender..
06-18-2015, 12:36 PM | #19 |
I just looked at the restomod website, man what a goat@#$!, not user friendly at all,
Most people just want to buy a complete package to mount/hook up and go, not jump around and try to find all the existing parts Probably go with some one else more user friendly
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
06-18-2015, 12:46 PM | #20 |
Just getting started on mine, i have my Vintage Air but i have not tried to install it yet. i was thinking on welding my mounting hardware to the inside of the dash abd just use nuts to hold it in place. |
06-18-2015, 01:23 PM | #21 | |
I am thinking once I get the VA plates here I will weld a stud to the inside lower mounting location. At the top I will bead roll a shallow stepped channel ..... like the one someone might make in a lap welded 1/4 repair. I will weld that to the upper location co that I can slip the unit up under the strip and just mount the bottom with a nut. the rest of the unit will be mounted to the cowl with the front evaporator mounting plate. |
06-18-2015, 05:31 PM | #22 |
Laid Back
Another shaved firewall but running the fittings out the front..
06-18-2015, 07:24 PM | #23 |
Mine is a southern air unit but, as you can see....before smoothing, after smoothing and then with the AC and Heater lines run through a bulkhead fitting
06-18-2015, 08:03 PM | #24 |
I recently redid my firewall and put the PB pieces in and got rid of some unused holes and smoothed all pinch welds out. I have a older Vintage Air system that was specifically for C10's and the unit outlets were too close to the firewall to do bulkhead type fittings, so I just cut up the plastic vintage air cover and used part of it.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
06-19-2015, 01:22 AM | #25 |
Subscribed as I'll be doing this to my truck soon.
1967 GMC 1500 SWB. Driving this truck since I was 14. |
