Old 10-25-2021, 08:06 AM   #1
71c10RDU
Help ID spindle!!
Ok I’ve done a fair amount of research and I’m stumped. I bought my 71 c10 and it already had drop spindles on it. There are no part numbers or branding stamped on them. I’m about to order tubular upper and lower arms and I’m not sure which year these are. The outter tie rods suggest they are in fact for a 71-72. However the castle nuts for the upper ball joints thread up so far the cotter pin doesn’t engage the nut. 🤷🏻*♂️ I don’t want to order the wrong arms. All my research suggests if the tie rods fit then that’s the year of the spindle, but the ball joints suggest otherwise. Maybe they installed wrong ball joints or castle nuts?? Here’s a couple of pics of the ball joints.
71c10RDU is offline   Reply With Quote
Old 10-25-2021, 12:47 PM   #2
67C10Step
67C10Step's Avatar
Re: Help ID spindle!!
Something does look funny with those castle nuts run way above the cotter pins.
Hopefully someone that recognizes the spindles will be along to advise better.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 10-25-2021, 12:53 PM   #3
71c10RDU
From the reading I’ve done it could be 1 of 3 things. Either the castle nuts are just wrong. (Not likely). Somebody put the wrong year ball joints in, or the spindles are for a 67-70 instead of a 71-72 (but the outter tie rod ends fit and according to the site and the measurements they are 71 tie rod ends). So I’m stumped. ����
Old 10-27-2021, 09:29 AM   #4
SCOTI
SCOTI's Avatar
I don't think we'll be able to accurately ID the spindle just by appearances on our monitors. You'll likely have to partially disassemble things to take some measurements & do some investigating.
With further info, we can help w/informed info vs. guessing.
Beyond that? Order your control arms as planned along w/a new set of spindles so you know EXACTLY what you have.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-27-2021, 10:09 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Are the upper ball joints riveted in?
This would mean they are original.
Keith
Convert to disc brakes.
Old 10-27-2021, 10:11 AM   #6
lolife99
lolife99's Avatar
Hope this chart helps,…
Keith
Old 10-27-2021, 11:02 AM   #7
Warrens69GMC
Warrens69GMC's Avatar
What dual piston calipers are those? That might lead you to your answer.
Warrens69GMC is online now   Reply With Quote
Old 10-27-2021, 11:06 AM   #8
71c10RDU
Update: I ordered an upper ball joint for a 71 and a 69. The 71 fit perfect. 69 did not. So while I have no idea why these castle nuts are so ill fitting, I do know the spindles are 71-72. I ordered my control arms accordingly. The dual piston calipers on there are wilwoods I recently installed. They work on any 67-72 disc brake spindle.
Old 10-27-2021, 03:50 PM   #9
SCOTI
SCOTI's Avatar
Good news there & that's how I would have validated stuff.
Maybe do the same test run on some lowers if possible? That would help rule out something funky going on @ that end. Since they're not 'installed' they should be easily returned.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-28-2021, 07:11 AM   #10
Joyridin
Are you sure somebody didn't modify those spindles? It looks like the castle nut doesn't fit because they milled a huge step in the spindle.
Joyridin is offline   Reply With Quote
Old 10-28-2021, 07:20 AM   #11
71c10RDU
Yes I’m sure. I installed my cpp control arms last night. Everything fit great.
