Old 03-26-2023, 03:24 PM   #1
85square
ORD Zero Rate Blocks
Does anyone have experience with the ORD zero rates? I've been meaning to buy a set so i can get an inch more lift in the front end.
Also, does anyone else make these? I like ORD products and have bought from them before, but it's going to cost $50 just to ship the zero rates and a new set of u bolts. I've considered making a set at home on my Bridgeport but i'm not sure it's worth the hassle.
85square is offline   Reply With Quote
Old 03-26-2023, 04:07 PM   #2
b454rat
Re: ORD Zero Rate Blocks
I have a set somewhere, along with their axle offset plates. Same thing, but only 1/4" thick so no (or very little) lift. I think DIY4X has some too.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 03-26-2023, 06:26 PM   #3
85square
Thanks, i'll check DIY. I'm only looking for a small amount of lift so i think an inch will be perfect.
Old 03-27-2023, 09:42 AM   #4
kwmech
One of 2 ways you can go. Buy these and bolt them on or get a similar piece with a centering hole and weld them to the housing. 1'' is the max I would consider for a spacer on the front. Personally, I weld them front and back to the spring perch and leave the spring pack alone.
Old 03-27-2023, 09:32 PM   #5
85square
Not a bad idea. 1” is definitely the biggest I would go too. I’m not too hot on adding anything to the front suspension really but at least these bolt to the spring pack and aren’t very tall.
