Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-13-2012, 10:25 PM   #1
70blazer
70blazer's Avatar
Applying my brakes blows my tail light fuse?
This is in my new 1967 Suburban. So I put a new 15 fuse in the tail light spot in the panel and I have all my lights. When I apply my brakes it blows the fuse and I lose my brake lights and dash lights... I put new tail light bulbs in and cleaned the sockets. Any other tips on what the issue might be? I might run out of 15 fuses in my little town if I use just my limited knowledge
Thanks in advance!
1967 Suburban, my kids call it the SuburBEAN cuz its long and green.
70blazer is offline   Reply With Quote
Old 02-20-2012, 09:22 AM   #2
john_p
Re: Applying my brakes blows my tail light fuse?
1st place to check would be where someone added a connector for trailer lights.. somewhere between that fuse block and your brake lights you have the hot lead for the brake lights touching ground... pinched wire or more common would be a bad splice.. keep the bean on the road..
john_p is offline   Reply With Quote
Old 02-20-2012, 04:01 PM   #3
70blazer
70blazer's Avatar
Thanks John, it does have a trailer brake setup with a home job wiring setup at the back! As soon as I can clear the foot of new snow off the Bean I will trace the wires and check all my connections/splices. Thanks for taking the time to help me out.....
Old 02-20-2012, 04:44 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's how I would troubleshoot this problem.
Disconnect the harness plug on the firewall behind the accelerator rod that has the rear light wires in it. Brown, light green, yellow, and dark green. Try a new fuse. If it doesn't blow then the short is in the rear harness. If it blows then disconnect the half moon harness to the steering column.
Try a new fuse. If it doesn't blow then the short is in the turn signal switch or the steering column.
If it blows then check the dome light circuit for a short to ground either in the light or under the sill plate by the drivers door in the harness there. That is a common place for the wires to chafe. If the dome light has been working then that won't be the problem. Most likely it's in the rear light harness.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-20-2012, 05:26 PM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
check the brake light switch sounds like every time you step on the brake pedal you blow fuses ,
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 02-20-2012, 11:24 PM   #6
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
In the burbs, the dome light harness is routed up through the driver's side A-pillar with the rear light harness. It passes through holes at the top & bottom that are drilled through sheetmetal and may be pinched.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-22-2012, 07:53 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Thanks OG I didn't know about the burbs. I hope we get feedback on this one.
VetteVet
Old 04-02-2020, 01:48 PM   #8
fishnixon
fishnixon's Avatar
Reviving this thread...I was hoping to hear what happened as well. It is not my intention to hijack thread, if that's what you call it, but there are so many threads where the result, good or bad, were not documented. I have a similar case of pressing the Brake Pedal and blowing a fuse, but my instrument and cab over lights go out. I'll keep searching, and I'll look into Vettes harness breakdown method as well.
UPDATE: with further searching I found VetVettes post regarding Brake Switch and the White wire which is common to grounding anywhere along the way, even to the turn signal switch...
fishnixon is offline   Reply With Quote
