02-13-2012, 10:25 PM | #1 |
Applying my brakes blows my tail light fuse?
This is in my new 1967 Suburban. So I put a new 15 fuse in the tail light spot in the panel and I have all my lights. When I apply my brakes it blows the fuse and I lose my brake lights and dash lights... I put new tail light bulbs in and cleaned the sockets. Any other tips on what the issue might be? I might run out of 15 fuses in my little town if I use just my limited knowledge
Thanks in advance! Posted via Mobile Device
1967 Suburban, my kids call it the SuburBEAN cuz its long and green. |
02-20-2012, 09:22 AM | #2 |
Re: Applying my brakes blows my tail light fuse?
1st place to check would be where someone added a connector for trailer lights.. somewhere between that fuse block and your brake lights you have the hot lead for the brake lights touching ground... pinched wire or more common would be a bad splice.. keep the bean on the road..
02-20-2012, 04:01 PM | #3 |
Thanks John, it does have a trailer brake setup with a home job wiring setup at the back! As soon as I can clear the foot of new snow off the Bean I will trace the wires and check all my connections/splices. Thanks for taking the time to help me out.....
02-20-2012, 04:44 PM | #4 |
Msgt USAF Ret
Here's how I would troubleshoot this problem.
Disconnect the harness plug on the firewall behind the accelerator rod that has the rear light wires in it. Brown, light green, yellow, and dark green. Try a new fuse. If it doesn't blow then the short is in the rear harness. If it blows then disconnect the half moon harness to the steering column. Try a new fuse. If it doesn't blow then the short is in the turn signal switch or the steering column. If it blows then check the dome light circuit for a short to ground either in the light or under the sill plate by the drivers door in the harness there. That is a common place for the wires to chafe. If the dome light has been working then that won't be the problem. Most likely it's in the rear light harness.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
02-20-2012, 05:26 PM | #5 |
~Rest In Peace~
check the brake light switch sounds like every time you step on the brake pedal you blow fuses ,
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
02-20-2012, 11:24 PM | #6 | |
Who's got steelies?
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
02-22-2012, 07:53 PM | #7 |
Msgt USAF Ret
Thanks OG I didn't know about the burbs. I hope we get feedback on this one.
04-02-2020, 01:48 PM | #8 |
Reviving this thread...I was hoping to hear what happened as well. It is not my intention to hijack thread, if that's what you call it, but there are so many threads where the result, good or bad, were not documented. I have a similar case of pressing the Brake Pedal and blowing a fuse, but my instrument and cab over lights go out. I'll keep searching, and I'll look into Vettes harness breakdown method as well.
UPDATE: with further searching I found VetVettes post regarding Brake Switch and the White wire which is common to grounding anywhere along the way, even to the turn signal switch... Last edited by fishnixon; 04-02-2020 at 04:25 PM. |
