06-12-2016, 02:12 PM | #1 |
Carrier bearing driveshaft to 1 piece driveshaft conversion
I have a 1974 c10 long bed that I am going to be lowering and was wondering if anyone has switched from a carrier bearing driveshaft to a one piece driveshaft? If so is there a factory one piece driveshaft that I might be able to source rather than having one built, any help will be much appreciated.
06-12-2016, 08:01 PM | #2 |
Re: Carrier bearing driveshaft to 1 piece driveshaft conversion
I have a 75 long bed that had a two piece drive shaft and was changed to a one piece. I think the carrier bearing support was removed for shaft clearance. This was done 25 years ago. I had a one piece shaft from a 77 and it has worked fine. Currently the truck is dropped 4/6 and the shaft has remained untouched other than u joint replacement.
06-12-2016, 09:33 PM | #3 |
I believe you are going to have a hard time finding a one piece driveshaft long enough. Chances are your transmission has a 6" tail? The trucks that came with the one piece shaft all had 9" tail transmissions. I had an 81 GMC with the 9" tale TH350, and a one piece driveshaft. The trans started slipping, so I picked up a good used TH350. Never realized it had a 6" tail. I ended up cutting the rear "yoke" off of my original driveshaft with a large Ridgid tubing cutter. Cut the rear off of another driveshaft 3" longer, and mig welded to my original. This is tricky process, had to make a "jig" to hold perfectly square during the welding process. Important that the weld is flawless as well. I was concerned about the shaft being out of balance after my repair, but got lucky and never had any vibrations.
06-13-2016, 12:37 PM | #4 |
I had one made for my k20 465-205 swap. Gave rm my old one and 100 bucks out the door I had a longer and new ujoints. I know my welding skills and have this to the pros.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
06-13-2016, 01:09 PM | #5 |
I thought about using one of the 1997-2001 Dodge Ram truck aluminum driveshaft. There the right length, almost to long. There is a shop here in Jax that can make it fix. They rebuilt my two piece.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
