Old 05-26-2015, 10:43 PM   #1
sodly
sodly's Avatar
TH400 howl
Anyone ever have a TH400 with a howl between, say, 20-30 mph? Only when torque is applied, not coasting. This is with a 4.57 rear, btw. Any thoughts? Bearing?
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 05-26-2015, 10:46 PM   #2
Hollow65
Hollow65's Avatar
Re: TH400 howl
Are you sure it's the trans? I've had rearend a make some god awful noises but never an automatic trans.
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 05-26-2015, 10:52 PM   #3
sodly
sodly's Avatar
Re: TH400 howl
It seems to be the trans. The rear end seems quiet. Replaced carrier bearing in the drive shaft as well.
WANTED:
Old 05-26-2015, 11:12 PM   #4
Hollow65
Hollow65's Avatar
Re: TH400 howl
Check the converter
Old 05-27-2015, 10:53 PM   #5
sodly
sodly's Avatar
Re: TH400 howl
The torque converter? Check for what, specifically?
WANTED:
Old 05-27-2015, 11:10 PM   #6
Hollow65
Hollow65's Avatar
Re: TH400 howl
When they go bad they growl/howl. You should hear it with the rear on jack stands. Have someone help you! Don't climb under with the truck in gear.
Old 06-25-2015, 11:35 PM   #7
TransMan1972
TransMan1972's Avatar
Re: TH400 howl
I would think if its the TC, the noise most likely would be heard all the time....the noise is being heard at a specified road speed range. Correct ? Maybe a torrington bearing in the T400 is coming apart....just a thought. (planetary area) Drop the pan on the trans, maybe piece of the bearing in the pan along with a bit of metal... Good Luck.
TransMan1972 is offline   Reply With Quote
