04-09-2018, 12:31 AM | #1 |
How to tell if truck or van tilt
I'm going to go look at a tilt steering column tomorrow and I want to make sure I'm not buying a van column how can I tell the difference thanks in advance.
04-09-2018, 12:55 AM | #2 |
Re: How to tell if truck or van tilt
Top bottom in picture below.
- Motorhome - Truck - Van. The fitting at the end of shaft comes off and the shaft is splined like the other 2. As you can see, the truck tilt has the neutral safety switch in a different location, the motorhome tilt has a bend in the part the auto transmission linkage attaches to, and the van has a longer shaft. |
04-09-2018, 12:55 AM | #3 |
I did a quick search on the forum's search engine and came up with this picture.
04-09-2018, 01:08 AM | #4 |
ok guys thanks for your help! Looks easy enough to spot the differences...
01-31-2023, 11:51 AM | #5 |
What spline are these columns? Thanks
03-10-2024, 01:36 AM | #6 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
03-10-2024, 02:38 AM | #7 |
Did not get any replies when I asked and ended up ordering the wrong joint for my steering. Going to help you out. My stock tilt is 3/4" x 36 spline.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
