12-30-2011, 09:42 AM | #1 |
Thinking of trading for a 70 Blazer
Hey guys I'm new here and I've always wanted a 1st gen Blazer to fix up. I recently found one near me(Maine) and I'm considering taking it. I want to know what you guys think is fair value for it. It has a crate 350 in it with 6000 miles. It's a 4 speed manual transmission. The 4x4 works and the truck fires up and seems to run well. The body is straight and the floors are good. It has a pin hole rust spot on the passenger side rocker panel. The odometer reads 82,000 miles. The truck needs restoration inside. The seats and carpet are junk. I will leave a link to the Craigslist ad. Will ad some pics when I get home to my laptop. Just want some opinions. Thanks
http://maine.craigslist.org/cto/2772069992.html Posted via Mobile Device |
12-30-2011, 11:05 AM | #2 |
Re: Thinking of trading for a 70 Blazer
looks like a solid truck and unabused! if its in as good as condition as it looks and you say its easily worth that price. score!
12-30-2011, 12:35 PM | #3 |
SKINNY TIRES RULE!
Welcome to the board. It looks like a solid truck but the photos are small and blurry. If you can get better pictures, that would help us.
The gearing isn't stock and is probably a bit overkill for those tires. If you're planning on going with bigger tires, it will be nice to have those already in there. The body is one of the main things to consider. Any rust you can see probably has near double hidden. The truck looks like it's in primer, so I'd check for signs of bondo covering rust. Lift the carpet (if any) - check the A, B & C pillars and unbolt the top and lift it to see if there is any rust in the windshield frame. Under the truck, behind the rocker panels are the torsion boxes (sometimes called rocker boxes). These are the structure for the truck when the top is off. If they are rusted, it is a big job to fix but reproduction parts are now available.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
12-30-2011, 12:54 PM | #4 |
Thanks guys! I will look at the rocker boxes and the other places. I am def planning on bigger tires, and new rims. The truck is actually painted flat black but I'm going to have it re painted factory blue( the interior is blue)On a side note another Craigslist ad in my area is selling a 69 and 72 Blazer for 1500 for the pair and says it is complete between the two. They are both the same blue as the one I am picking up and looks like they have a lot of parts I could use. Rear bumper, factory roll bar, blue bucket seats etc...
12-30-2011, 01:13 PM | #5 |
Do you guys know how big I can go on the tires with no lift?
12-30-2011, 03:23 PM | #6 |
needs more $$$
I've read 31's at most, but don't have a 4x4 myself. Good luck with the buy/trade!
1970 2wd Blazer |
12-30-2011, 06:04 PM | #7 |
The guy told me the rocker boxes have been removed. How big of a job is to put them in?
12-30-2011, 06:55 PM | #8 |
There is no rust at all around the windshield frame
12-30-2011, 07:24 PM | #9 |
Equal opportunity joke ofender
friend of mine had 33's on his stock one but you could not turn lock to lock without rubbing. Put 31's on and it was no problem
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
12-30-2011, 08:15 PM | #10 | |
SKINNY TIRES RULE!
I believe there is a tread on the board where someone replaced their boxes. Do a search for either rocker boxes or torsion boxe.
12-31-2011, 12:23 AM | #11 |
33's fit fine on mine without a lift. Use a wheel with as much offset as you can get away with. Works great on mine on and off road.
12-31-2011, 09:24 AM | #12 |
You could offer 4500 for it whats the worse that can happen he says no. Post some pics or a link to the other two Blazers.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
12-31-2011, 02:04 PM | #13 |
I believe the 4:11 gears are stock for a 4 speed Blazer. My Jimmy with 4 speed also has 4:11s.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
12-31-2011, 05:17 PM | #14 |
I checked it out today. It needs quite a bit of work so I don't think I'm going to get it. I have a 99 Harley softail custom if you guys know anybody interested in a trade for a decent 1969-72 K5. Needs to be a daily driver. Thanks for all the responses!
