Old 06-19-2021, 09:49 PM   #1
tim71
tim71's Avatar
WTB Rear Axle Leaf Spring Plate
I need 2 of the rear axle plates that sit under axle, the axle u bolts go through plate and secure axle to leaf springs.
Needed for a 1972 Blazer. I'm sure all half ton K trucks use this attaching plate.
Good chance 2WD trucks with leaf springs use the same plate.
PO lifted Blazer and changed axle/leaf spring setup. The u bolts are supposed to face down. PO added lift blocks and a round u bolt that faced up. The improper plate on Blazer is on top of the leaf springs and is incorrect.
I'm attaching a photo of the correct attaching method and you can see the plate under the axle...I need 2 of these. Thanks for any help.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 06-21-2021, 02:53 PM   #2
jamie72
jamie72's Avatar
Re: WTB Rear Axle Leaf Spring Plate
I should have a set. pm your cell i`ll send a pic.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
