Old 06-04-2014, 02:56 PM   #26
Pappyx3!
Pappyx3!'s Avatar
Re: Upgrade to power brakes from manual
mschwader,
Looks like a nice start, impressed with the shape of that interior. Maybe a little jealous... What's your build plans?
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline   Reply With Quote
Old 06-04-2014, 03:11 PM   #27
1963c-10
1963c-10's Avatar
Originally Posted by 66Submarine View Post
Probably could find one on the forum here. Sucks that it's missing one, though.
It does look like a very nice truck! What engine does it have in it? I guess it would have had/has a 283 or 235 being a '62.
BTW, now I see you said "GM HO 10 bolt" 1963c-10. I've never called them that, so I tend to associate that with people confusing the smaller Eaton rears in the pre-'63 half tons for the later 10 bolt GM rear. FWIW, the Eaton 52/72 was actually used under 20-30 series (3/4-1 ton) trucks all the way from 1947 (IIRC) until the introduction of the 14 bolt that replaced it in 1973.
GM HO32 w/10 bolt cover....sorry 66Submarine.... was the standard 10 series rear diff and like yo said 52/72 in the larger series.
All parts point to it being a 62....I'd definitely check vin and frame number to see what you have.
1964 Short bed trailer
Old 06-04-2014, 04:09 PM   #28
mschwader
Originally Posted by Pappyx3! View Post
mschwader,
Honestly I think I want to start with the body and then in. It's got a running motor. Something most aren't lucky to find I suppose. I'm not a huge gear head anymore. At least not like I used to be. Had a 79 Chrysler 300 (came stock with a 360), 90 Chevy 454 SS (probably my most missed), 96 Camaro SS, and then a 2001 Subaru RS. I'm more traditional now in the fact that I own two newer Suburbans. I want to stay carburated. I don't really like the fuel injected idea on an old truck. I gave some thought to throwing a big block in it but it sounds like there is a lot more modification needed than just sticking a 327 or 350 in it. I'm more of a put around guy than a lead foot now.
As far as the body goes. I like the 62 Hood more than the 60 Hood so I'll stick with it. REALLY contemplating changing the bed to a Long Step Side. I already have the fenders and front and rear of the bed off a 60 in may garage. I'm pretty sure I can use those. All I should need is the longer steps in front of the wheel well, the rear steps, and the inside bed walls.
mschwader is offline   Reply With Quote
Old 06-04-2014, 04:26 PM   #29
1963c-10
1963c-10's Avatar
Long bed fleet to long bed step is pretty easy to do. There are different mounting locations for the bed though. The long bed stepside parts (side panels and steps) are not reproduced and a little harder to find, but they are out there....and no steps behind the fenders....just in front. If your considering a swap, I'd look for a donar bed instead of parting it together. It'd be cheaper to do. The front bed panels and tailgates for the stepsides are pretty much interchangeable from late 55-66 so that should help you with your search.
Old 06-04-2014, 04:31 PM   #30
mschwader
Good to know. There was someone on here down south that I spoke to a while back that was going from Step to Fleet Side and said he would possibly sell his. I'll have to check with him. I've seen some long bed steps that had a step behind the wheel. Must have been a custom job. Thats good to know too. Havent found too many goo photos online that show the back part of the beds.
Old 06-04-2014, 04:41 PM   #31
1963c-10
1963c-10's Avatar
They were probably step bumpers which were normally dealer installed. The step bumpers wrap around the back of the trucks and are normally very heavy duty bumpers
Old 06-04-2014, 07:29 PM   #32
mschwader
Originally Posted by mschwader View Post
BTW its for a 63 C20
Since I know everyone is dying to know. I finally have the correct answer. It's a 62. I have no idea why I thought ut was a 63. I specifically remember reading about the changes made to 63's and up and being jealous because I had the 62.
Anyway heres a picture of the front wheel. Doesn't look like ive got coils on the front.
Old 06-04-2014, 07:48 PM   #33
66Submarine
66Submarine's Avatar
BTW, from my understanding most (maybe even all?) of the parts are the same for the '55 (2nd series) to '66 stepside beds. I know the fenders and all that stuff is supposed to be '55-'66, and IIRC the tailgate is actually a '47-'87 part somehow.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 06-05-2014, 12:06 AM   #34
Captainfab
60-66 Nut
Looks like a fairly decent truck
I agree that it is a '62 C20 with either a 235 or a 261. Most likely a 235.
I do have a single 8 hole 17.5 wheel if you are interested.
Old 06-05-2014, 12:50 AM   #35
mschwader
Really? What are you looking to get for it?
Old 06-05-2014, 08:23 AM   #36
1963c-10
1963c-10's Avatar
Ohhh...and I saw in the new Class Industries catalog I got yesterday that they are reproducing the long bed stepside bedsides......
Old 06-05-2014, 08:27 AM   #37
1963c-10
1963c-10's Avatar
Pretty close....
47-53 had a different design tailgate than the 54-87
Old 06-05-2014, 09:19 AM   #38
Ronw435
Ronw435's Avatar
Yeah I bought what I thought was a 64 as it came with a 64 title. The truck did not have a vin plate on the door frame but after removing the body parts found the number on the frame saying it was a 65, also the motor turned out to be a 65 so have to go through the 68A form here in Texas to get it retitled. The North Texas Auto Theft Task Force at least told me the truck is not stolen so that was a relief. But in order to get a new correct title with a new vin plate I have to get the truck completed and take it to them for inspection and then I can get the correct title and be able to get a new vin plate.
Ronw435 is offline   Reply With Quote
Old 06-05-2014, 12:25 PM   #39
66Submarine
Pretty close....
That's what I've always thought, thanks for the picture. Can't remember who was saying it goes back to that, but I guess they got confused if it was used in '54; probably extrapolated that back or something. I think I read it on a parts site selling them, though; hopefully they've corrected that by now!
Old 06-05-2014, 01:06 PM   #40
1963c-10
1963c-10's Avatar
I actually see that a lot with the tailgates being listed for the wrong years by vendors.
Old 06-05-2014, 01:56 PM   #41
mschwader
So how hard is it to upgrade to coil springs on a 62?
Old 06-06-2014, 12:23 AM   #42
Captainfab
60-66 Nut
$35.00 plus shipping
Old 06-06-2014, 12:24 AM   #43
Captainfab
60-66 Nut
You will have to do a complete suspension and crossmember swap. May as well upgrade to discs with power steering and brakes if you're going to all that work.
Old 06-06-2014, 12:28 AM   #44
mschwader
I have found 63 and up conversion kits. Any idea where I can find everything I need for this 62?
Old 06-06-2014, 12:29 AM   #45
mschwader
If you dont mind, can you post a picture?
Old 06-06-2014, 12:33 AM   #46
Captainfab
60-66 Nut
I'll have to get a pic when I'm at my shop tomorrow.
Old 06-06-2014, 12:50 AM   #47
mschwader
Sounds good, thanks!!
Old 06-07-2014, 12:07 PM   #48
Captainfab
60-66 Nut
Here's a pic of the 17.5 wheel I have. I still need to peel the tire off of it.
Old 06-10-2014, 01:02 AM   #49
mschwader
Thanks. Paypal?
Old 06-10-2014, 01:09 AM   #50
Captainfab
60-66 Nut
Yes PayPal works. I'll have to get the tire off of it and get a box and weight. What is your zip?
Thanks. Paypal?
brakes, manual, master cyclinder brakes
