Old 02-05-2010, 12:30 PM   #1
stevewhitmore
stevewhitmore's Avatar
Kugal Automatic Shift Linkage
Has anyone installed this linkage or the similar product from Lokar and if so did it take the sloppiness out of your column shifter?
I think my linkage at the trans was homemade and it is extremely sloppy at the column.
I am hoping that this might do the trick in place of a new column.
Thanks for any guidance
stevewhitmore is offline   Reply With Quote
Old 02-05-2010, 12:39 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Kugal Automatic Shift Linkage
I used this on my first '68 when I put in a 700R4. Worked perfect and no slop was experienced. Going to do this on my current one even with the stock TH400, just so I can get rid of the frame mount setup.
Now if your column is worn out and has a bunch of slop, you'll still need to correct that.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 02-05-2010, 12:42 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I used the Locar shift lever, i installed a 4l60/4.8l. it is firm and no slop at all.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-05-2010, 12:50 PM   #4
leddzepp
Moderator
leddzepp's Avatar
I used Kugel Komponents (same as Lokar, less expensive) worked perfectly.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 02-05-2010, 01:33 PM   #5
57larry
I used it on a street rod (chevy engine, turbo 350) works great and has for the past 6 yrs
57larry is offline   Reply With Quote
Old 02-05-2010, 07:48 PM   #6
gmc1971harwich
gmc1971harwich's Avatar
where do i get a kit like that for my 700r4 column shift?
gmc1971harwich is offline   Reply With Quote
Old 02-05-2010, 08:13 PM   #7
DPowers
DPowers's Avatar
I put a Kugel on my '66 with 350TH.
http://www.shiftworks.com/index.html
Mike's Bump N Grind- mgbmike on this site sells the Lokar
DPowers is offline   Reply With Quote
Old 02-05-2010, 10:07 PM   #8
gmc1971harwich
when I install this linkage how do i modify the detent plate at the end of my column? my column is a 71 non tilt with the detents for park and 123 at the bottom of the column il try and get a pic to show u what i mean
Old 02-05-2010, 10:23 PM   #9
gmc1971harwich
this is not my own column but has the same detent
Old 02-05-2010, 10:30 PM   #10
DPowers
DPowers's Avatar
It should adjust ok-
My column is off a '64 Impala
Old 02-06-2010, 01:42 AM   #11
leddzepp
Moderator
leddzepp's Avatar
It is adjustable, can be dialed in to a 350, 400, 700R4, etc.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 08-29-2019, 06:50 PM   #12
howell57
Has anyone you know done a 6L80 into a 72 C10 and used ??? for linkage? I'm "Old School" and this new stuff is like learning all over again!
howell57 is offline   Reply With Quote
Old 08-29-2019, 07:59 PM   #13
samkost
samkost's Avatar
Alright guys, you got my attention!
On my 72 with tilt column I replaced the original TH350 with a 700R4.
Installed a new 4 speed indicator (pointer) window on the column with the original linkage.
I was always told to accept the fact that the pointer (gear indicator) would be off/misaligned with the new 700R4 upgrade.
Will these linkage kits correct this misalignment of the pointer more accurately?
chevy mike stated with his 700R4, that slop in the column will play a factor.
My tilt column has always worked well and is in great shape.
If needed, does the column need to be disassembled to correct any internal slop for the indicator?
Thanks everyone
samkost is offline   Reply With Quote
Old 08-29-2019, 10:56 PM   #14
tdangle
tdangle's Avatar
By adjusting the distance from the shift shaft on the trans to the rod that comes up to the column I was able to make all the positions line up with the indicator.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 08-30-2019, 12:00 AM   #15
Gromit
Hopefully this is not too off topic but I think it is related..
When I replaced my cab rubber mounts I was a little worried about stressing the TH350 automatic shifter linkage on my 1970 C10 during the installation - I debated unhooking it - but then I just decided to put the selector in neutral and monitored the slop in the linkage as I slowly jacked up the cab enough to slip the new rubber cab mounts in - it was only about an inch or so.
Anyway I suspect there is so much slop in these auto shifter linkages because the cab (where of course the shift lever happens to be) is on those rubber mounts and the cab must be free to move relative to the transmission and chassis mounts and as the mounts flex - up to say 3/4 of an inch or so in all directions - you wouldn't want the shifter to go into reverse when you go over a whoop-de-do
But still I do think it would be a major improvement to eliminate the slop and make the selector feel more definite.. like a Jaguar?
Gromit is offline   Reply With Quote
