Old 09-07-2023, 09:40 PM   #1
4793
4793's Avatar
DOT 4 fluid for clutch- why?
My avatar truck is an '02 K2500 with the 8.1/ 6spd manual. Noticed the other day the clutch reservoir was on the low side and *then* I noticed the cap said "DOT 4 only". I just had DOT 3 brake fluid on hand so I did a little research and made a phone call to a trusted mechanic- long story short I ended up going to town for a bottle of DOT 4. The brake system in this truck takes DOT 3 and I end up wondering why the clutch wouldn't use the same fluid?
(if this has been covered somewhere, apologies, the search results were inconclusive)
4793 is offline   Reply With Quote
Old 09-10-2023, 05:06 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: DOT 4 fluid for clutch- why?
DOT3 & DOT4 are both glycol based brake fluids. DOT4 has a significantly higher dry and wet boiling point. I'm not sure why they would use it in the clutch and not in the brakes from the factory. Good possibility someone changed the clutch master cylinder reserviour cap.
DOT4 is downward compatible so you don't have to clean the system entirely to update to DOT4. I run DOT4 in everything. An extra couple hundred degrees boiling point is a good thing when towing.
I changed the brakes on my 05 Silverado and my 09 Impala over to DOT4 when I flushed the brakes several years ago. I replaced the DOT3 master cylinder cap with the 92457850 DOT4 MC cap.
This is the post on flushing the brakes in my build thread. http://67-72chevytrucks.com/vboard/s...8&postcount=68
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-11-2023, 09:45 AM   #3
4793
4793's Avatar
hatzie: thank you. It never occurred to me the cap might have been swapped out. Also thanks for explaining the difference between 3 and 4. My local guy said the same thing you do, that 4 could be added to 3 but not vice versa, but he wasn't real keen on the idea. The truck spent the first ten years of its life in the southwest US (not sure precise location) and maybe that has something to do with using a fluid with a higher boiling point
Old 09-11-2023, 01:52 PM   #4
95 S_Trucker
95 S_Trucker's Avatar
The service manual calls for GM# 88958860
That is DOT 4 fluid. Nobody switched the cap.
95 S_Trucker is offline   Reply With Quote
Old 09-11-2023, 08:10 PM   #5
hatzie
Moderator
hatzie's Avatar
I've never had a T800 with a manual transmission.
Not sure what the reasoning was to do that. The clutch on my T400 used DOT3.
As I said. I run DOT4 in everything with brake fluid in it.
Old 09-13-2023, 12:29 PM   #6
4793
4793's Avatar
You're both right, it seems. The owner's manual refers to "GM Hydraulic Clutch Fluid" (which until now I didn't know was DOT-4) with the part number 95 S Trucker listed for the 6 speed, and DOT-3 for the 5 speed. I guess if they had to make things this complicated it's no wonder people gave up on sticks.
