Old 01-26-2023, 04:55 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Jack Instructions, Stow Away
After having installed these, today marks the first I have nothing left to install in my rebuild, Pending stuff. The seat cover has been on order 6-7 months under a covid economy.
Apparently I get my $1100 OER radiator tomorrow though. Yeah, $1100 for what I hope is solid, from USA Radiator. The last two are junk and came from different manufacturers.
Anyone able to find this decal? I found a "replacement" decal, but that's not it.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
Last edited by 71CHEVYSHORTBED402; 01-27-2023 at 01:48 AM. Reason: Revised due to new information
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-26-2023, 07:20 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Jack Instructions, Stow Away
I have never seen a jack like that in a '67-'72 C10, 20, or 30. I wonder if it could be a decal from a C40, 50, or 60 I don't know if they even had a jack.
The 5th picture is how the tool bag spring should be mounted.
LockDoc
Leon
Old 01-26-2023, 07:30 PM   #3
jabborabbo
jabborabbo's Avatar
LockDoc
My ‘67 GMC has a jack like that….
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is offline   Reply With Quote
Old 01-26-2023, 07:31 PM   #4
LockDoc
LockDoc's Avatar
Does your truck have a decal like his first picture?
LockDoc
Leon
Old 01-26-2023, 09:12 PM   #5
Casper42
Casper42's Avatar
1. your decal shows a 4 headlight GMC, and the jack certainly looks odd. Mine is the common one that's available as a reproduction.
2. your lower floor spring latch is mounted backwards, compared to mine in a 72 C/10
3. your upper spring latch is identical to mine, with proper placement.
this all suggests, if you have a Chevy, the manufacture put the incorrect lable, or your cab was replaced, maybe?
Casper42 is offline   Reply With Quote
Old 01-26-2023, 10:19 PM   #6
71CHEVYSHORTBED402
LockDoc
I suppose you mean the jack instructions in the first pic. Can't say for sure, I only got the truck in 1989, though I can't say why the original owner would change the decal.
Come to think of it, the jack I pulled from the truck seems to match the decal I was informed it was the wrong jack. Hmm. Both replaced or factory?, hmm.
Seems the jack's bracket installs either way, my 72 is like yours. I found my 71 like what's pictured and it matches the assembly manual, pic. 5.
Cab wasn't replaced but interesting that decal and jack is for a GMC. Might the difference be my 71 SWB 2WD was ordered with leaf springs, which came stock on GMC? But then, why would the jack be different for leaf springs?
For what worth here's the jack I removed from the truck, which matches the decal instructions. Not saying it's original, but I learned long ago what must be doesn't always apply. Other than that, I can't find those instructions anywhere.
Tony
Old 01-26-2023, 11:45 PM   #7
Casper42
Casper42's Avatar
Yes! that is one unusual looking jack, IMO. and it looks taller than what is typically OEM. Do you have a 4x4 perhaps? I had a 72 GMC 4x4 but that was in the 80's and cannot recall what it had.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Old 01-26-2023, 11:56 PM   #8
71CHEVYSHORTBED402
Nope, 71 Chevy 2WD SWB with leaf springs. Until you guys chimed in, I hadn't noticed the jack matches the decal. At the moment I can't find either anywhere. Interested to know if jabborabbo has a decal to match his jack.
Tony
Old 01-27-2023, 01:14 AM   #9
LockDoc
LockDoc's Avatar
I don't think you are going to find that jack decal anywhere unless you stumble on to an original one left over from a dealership or something. I reproduced the '67 only, Chevy jack instructions decal but it is different that that one.
LockDoc
Leon
Old 01-27-2023, 01:36 AM   #10
71CHEVYSHORTBED402
LockDoc
Agree. At this point I'm just trying to verify it's original to the truck. Seems it would be considering the matching decal, but the cab floor may imply it takes the more common jack, and the decal shows the jack stored in what appears as the wrong direction I may just use a standard bottle neck.
Tony
Old 01-27-2023, 08:38 AM   #11
jabborabbo
jabborabbo's Avatar
LockDoc
I haven’t seen a jack decal of any kind…
Old 01-27-2023, 12:15 PM   #12
72c20customcamper
72c20customcamper's Avatar
Never seen a screw type jack in anything under a one ton truck (not longhorns ) like tow trucks or camper bodied dually. Strange indeed
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-27-2023, 12:20 PM   #13
OregonNed
OregonNed's Avatar
There is a company local to Oregon (https://www.fillingstation.com/) that sells a lot of decals on their site - including the jack instruction ones - that might be a source for you. Good folks there.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 01-27-2023, 02:26 PM   #14
BROWN 70
BROWN 70's Avatar
hi guys, is the jack bag reproduced? thanks brown 70
BROWN 70 is offline   Reply With Quote
Old 01-27-2023, 03:27 PM   #15
LockDoc
LockDoc's Avatar
There was a guy on here making them but I don't know what his status is at this time. I can't remember his board name.
LockDoc
Leon
Old 01-27-2023, 07:23 PM   #16
FirstOwner69
FirstOwner69's Avatar
Here's a link to the bags LockDoc referred to. However, that thread says it's closed. Not sure why.
https://67-72chevytrucks.com/vboard/...d.php?t=715455
Jim
FirstOwner69 is offline   Reply With Quote
Old 01-28-2023, 10:34 AM   #17
BROWN 70
BROWN 70's Avatar
thanks for the info guys, brown 70
