04-16-2022, 10:52 PM | #1 |
1968 Chevrolet CST Survivior.
Cardinal Red 1/2 ton v8 auto trans. Gonna be a Badass Parts runner!
Posted via Mobile Device |
04-16-2022, 10:54 PM | #2 |
More pics.
04-16-2022, 10:58 PM | #3 |
More. Anyone know the engine code?
04-16-2022, 10:58 PM | #4 |
Found the missing door panel it was behind the seat!
04-16-2022, 10:59 PM | #5 |
Fun stuff! Knocking of some of the “Old Man” of this Hotrod truck!
04-16-2022, 11:05 PM | #6 | |
Old man mirror removed, stock shiney replacements are ordered! Back window Sticker removed! Posted via Mobile Device |
04-16-2022, 11:35 PM | #7 |
Re: 1968 Chevrolet CST Survivior.
S U B S C R I B E D !
Tell us more about your plans.
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Project "Little Sister" (70 c10 blue original paint refresh) Project "C10 Fever" (68 factory black 396 swb) Project "Blue Bomb" (70 c30 blue original paint refresh) Project "Vitamin C" (71 c10 orange original paint refresh) |
04-17-2022, 02:18 AM | #8 |
My plan is to front disc brake swap with dropped spindles, lowered springs front and rear, 15x7 front and 15x8 rear rallys with staggered tire sizes. Keep this truck SIMPLE and CHEAP clean it up give some attention and use it as a parts runner! One last thing… do not SELL IT!!
04-17-2022, 08:58 AM | #9 |
Nice truck
Defiantly a Keeper. About the engine code , It appears to be L30? This is from Outintheshop's info/ L30:327 CU. IN. V-8 ENG. L30 is a 327. https://www.outintheshop.com/options.html
04-17-2022, 09:17 AM | #10 |
Roadtrip!
Engine should be a 327. Choke delete came on 327 or 396 in 68. Looks like a good truck.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
04-17-2022, 03:43 PM | #11 |
Glad you are keeping this one!!!
I see what looks like a Quadrajet on the engine, that would have to be a 327??? Always glad to see disc brakes on a 69 and earlier!!! |
04-17-2022, 07:23 PM | #12 |
I love that truck. Had one just like it in the early 80s. Its the only c10 that I regret selling. But back then, they were everywhere. Good plan for it too. I will be watching this one for sure.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
04-19-2022, 10:11 PM | #13 |
I’m glad you ended up with it!!
You will do all the proper mods and repairs, and it will be great!!!! |
04-19-2022, 10:45 PM | #14 |
Thanks for the engine info and kind words !
Posted via Mobile Device Last edited by hardwaa; 04-23-2022 at 05:43 AM. |
04-19-2022, 10:49 PM | #15 |
Oil pressure check. No psi reading with stock gauge. Napa mechanical gauge to the rescue. We have oil psi! Engine was to quiet not to have non maybe stock gauge is gummed up. Pulled oil line from engine block to coupler at fire wall blew stock line out. Napa gauge showed 25 psi at cranking and 40 ish at idle.
04-19-2022, 10:52 PM | #16 |
Installed tailgate. Pulled stock tank out for scrap. Truck is begging for a goos wash. I did wash interior drivers cab corner and rinsed it off What a DIFFERENCE!!
04-19-2022, 10:55 PM | #17 |
Installed a quick gas tank in bed and installed all new fuel hose with a filter to see if fuel pump works. It does but fuel pump leaks like a fountain when I trueness truck off. Will replace fuel pump next
04-19-2022, 10:58 PM | #18 |
I did manage to round up 4 6 lug rallys! 2 15x8 for rear and 2 15x7 for the fronts. Also did check lights all work even the Horn!
04-21-2022, 11:47 AM | #19 |
chevy truck fan
hardwaa, nice "new" addition! I like to follow your builds.. kinda a "roadkill" flavor with a "overhaulin" flair! will keep up on this one as well...
04-24-2022, 01:01 AM | #20 |
04-24-2022, 01:04 AM | #21 |
Progress. Replaced fuel pump. Took test for testdrive, just around the neighborhood, starts, idles, shifts 3 forward gears and reverse gear and stops.
04-24-2022, 01:06 AM | #22 |
Some shiney parts, interior door locks and exterior mirrors.
04-24-2022, 01:08 AM | #23 |
More pics I even washed the tailgate off.
04-24-2022, 01:10 AM | #24 |
Removed some of the ancient AC. No more AC compressor, lines, dryer, condenser.
04-29-2022, 10:46 PM | #25 |
My steering wheel showed up! Big thanks to Mr Kieth “lolife” on here. He gave me some info about these steering wheels. Then I seen this smaller red 1 and I bought it! This steering wheel is 1 1/2” smaller OD and 1”
Shorter overall height than the stock 68 truck wheel. I really like the fact that it’s a factory looking steering wheel to boot. Posted via Mobile Device |
