03-21-2016, 11:44 AM | #1 |
Intro and question about towing with a C35 one ton
Hey everyone! I am moderator of fsjnetwork.com where we talk about the old full sized jeeps. I built a '78 J10 Honcho a few years ago into a rock crawler and now I have built a '75 GMC C35 one ton 2wheel drive dually so I can tow the Honcho. My Dad actually had the exact same truck that he bought new in '77. Same color and everything. He had that truck on the farm and it rusted out a few years ago though.
I installed a 2005 8.1L L18 backed by a new gearstar 4L80E tranny into the C35. Swap notes include the following: stock radiator stock starter for a 454 stock headers for a 454 stock engine mounts stock transmission crossmember that I moved to the rear position because the 4L80e is longer than the stock TH400 The truck is a 100% rust free Colorado truck and is in amazing condition. It rides and drives great. No issues with it at all. My question is surrounding towing capacity. I've recently completed the truck and bought a 34' gooseneck trailer with the intentions of towing my rock crawler and maybe another rig if needed. The trailer weights 4600lbs and the J10 weights 6000lbs. I have a new B&W GN hitch (the one rated for 30K). I loaded up the jeep this weekend and took everything for a test drive. All went well, but I could definitely tell the trailer/truck was back there. What is the max towing rating for these old C35's? |
03-22-2016, 12:04 PM | #2 |
Re: Intro and question about towing with a C35 one ton
Welcome to the site,
Your year truck GCW will depend on the rear gear that came stock. If it's a 3.73 it's 13,000 and if it's a 4.10 or 4.56 than its 15,000. You should also have trailering special GCW name plate right next to the window molding on the door if it's a trailering special model...
Long live SLIM ------------------ At least try to buy American |
03-22-2016, 12:45 PM | #3 |
That's a good looking combo there Blake. When I get my 85 Crew in good enough shape I will be dragging my crawler out to your neck of the woods.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
03-22-2016, 01:27 PM | #4 |
These old trucks aren't quite as heavy as newer ones, which causes it to feel like the trailer is pushing you around. For comparison sake after I bought my '90 V3500 crew cab I took it to the scale empty and it was right about 6500#. Shortly there after I took my dad's '97 k3500 crew cab to the same scale empty and it was just over 7500#. Both trucks are 454 automatic trucks. The '90 had the Dana 60/70 combo with the NP205 transfer case. The '98 had the ifs and a corporate 14 bolt rear end and the aluminum chain drive t-case.
You have the power with the 8100, I just think the lighter weight of the older trucks makes a huge difference. Nate
Current Project: 1990 V3500 CC dually. |
03-22-2016, 10:35 PM | #5 |
I have no answer to your question... However that is such a badazz combo, that whatever small towing disadvantages you may be experiencing you make up for and then some in style points!!
03-23-2016, 01:45 PM | #6 |
What accessory set did you use for the swap? I'm seriously considering an 8.1 swap with an allison or NV4500.
74 K20, 454, SM465, NP208, 14FF, D44 14 Silverado 5.3 07 Victory Hammer, Bassani, intake, auto-tuner 00 Formula, 6.0, LS3 heads, X-pipe, etc, etc, etc - SOLD |
03-23-2016, 01:54 PM | #7 |
At the body shop.
Had a '86 1t with a roll back bed, and pulled a 24' open car trailer.
454 4 speed 4:10 gear doug nash od Have had 2 '55 caddys on it. About 22k or so, Pulled it fine, stopping however not so much. Still 300k+ in it.
" That didnt make it any newer " " Dont antique the equipment " |
03-23-2016, 04:35 PM | #8 |
I believe Slim is spot on with the GVW's vs gear ratio. I have a 79 1 ton 454 with 3.73's and 13,000 GVW is what I recall.
I've pulled my 28 foot enclosed across country with it. Empty the trailer is almost 5,000 lbs., had a 4100 lbs. car in it, air compressor, generator, complete 5 foot tall tool box packed with tools etc... Every bit of 10,000 lbs. if not more and it did a fine job pulling it around. |
03-23-2016, 07:06 PM | #9 | |
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
03-23-2016, 07:19 PM | #10 |
Here you go...GCWR in pounds by axle ratio
03-23-2016, 07:26 PM | #11 |
Speaking 1 tons with a 454 it looks like
3.73's = 13,500 lbs. 4.10's = 15,000 lbs. 4.56's = 17,000 lbs. |
03-23-2016, 07:37 PM | #12 |
Well sure, if you jump to the 1978 data. Given the minimal changes from 75 no doubt the info is applicable, but it's not the GM gospel for the OP's model year.
03-23-2016, 07:44 PM | #13 |
Isn't much GM says I'd take as gospel but it's a pretty safe bet those trucks went virtually unchanged from 73-79 so I wouldn't have a problem applying that chart to any of those years.
03-25-2016, 07:48 PM | #14 |
I've had 20K behind mine on the gooseneck behind mine. tows and stops just fine, but I have 4wheel disc, and a little better than stock drivetrain! These are tough old trucks!
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
07-27-2021, 03:13 PM | #15 |
Hey guys, I'd like to post an update on my old square.
I built this thing 5 years ago with the intention of towing my rock crawling rigs to the trails. Then life changed and I ended up moving to an epic offgrid property 8500 feet in elevation. I'm on a 6 mile dirt road that is very steep. The road is washboarded and bumpy. I've been hauling water up here for over 4 years with the old dually (and a taco). Mostly been hauling 450 gallons at a time with the tank in the bed. That is 3300lbs and the truck handles it well. It's a 40 mile round trip run to Estes Park CO from my place. 14 miles of 45mph windy hwy and 6 miles of dirt road all uphill. I ended up putting in 5.13 gears in the stock D70HD (on stock tires) and that really helped getting loads of water and materials up here. Now here is my question based upon this rig '75 GMC C35 2wd with an 8.1 /gearstar 4L80E / 5.13 gears and detroit. Otherwise stock truck on stock springs. My question is: Should I be worried about hauling 16klbs of gross vehicle weight with this old truck? It handles it prettty well, but man this 6 mile dirt road is rough and steep. |
07-27-2021, 03:50 PM | #16 |
There's two things you need to worry about. What's legal to tow, and what's safe to tow.
Legally, you can't exceed the truck's GVWR. That's the weight on the two axles of the truck, including trailer tongue weight, but not including weight on the trailer axles. I'm almost certain you're good to go there. Safe towing capacity is based largely on how the rig feels when driving it. If you're comfortable doing what you're doing, that's the most important thing.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
07-27-2021, 04:46 PM | #17 |
As long as everything is in good shape and you don't bust the GVWR, the truck is doing what it was designed to do. But except for the new parts you swapped in, that truck is ~47 years old. You should keep in mind that on a steep rough road at altitude, things can go from great to crap really fast. Going down that bumpy hill with 16k and finding out you forgot to connect the trailer brakes.... (or a mouse chewed on some wires to the same effect).
07-27-2021, 04:58 PM | #18 | |||
Having been the one that established the trailering rating for some of these vehicles I can say the limiting factor was the ability to launch the vehicle at GCW up the 16% grade. There were a number of combinations that would have been rated higher if it were not for this particular requirement. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 07-27-2021 at 05:04 PM. |
07-27-2021, 05:10 PM | #19 |
I don't tow anything DOWN the mountain. It's always UP the mountain.
The truck drives and handles and brakes great when loaded. I only have the Gooseneck. No bumper pull. I guess I worry about the integrity of the leaf springs and the frame. They all look good, but ~46 years is a long time. |
07-28-2021, 12:45 AM | #20 | |
As far as I can tell, the only number that matters to law enforcement is the GVWR. I welcome correction though. Edit: Was the GCWR a legally binding thing back in the squarebody days? It looks a lot more like a factory "recommendation" that might affect warranty claims at best. After all, there's nothing inherently unsafe about towing a heavy load with a 3.42 axle ratio. DOT doesn't care how heavy towing affects your drivetrain. They just want to know your chassis, tires, and brakes are big enough.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! Last edited by kipps; 07-28-2021 at 07:58 AM. |
07-28-2021, 03:16 PM | #21 | |||
My point was that GVW and GCW are two different animals. Quote:
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-28-2021, 03:19 PM | #22 | |
K
07-28-2021, 03:20 PM | #23 |
To some degree, it also affects the amount of stress on the engine and transmission. A 3.42 will run a higher risk of clutch damage than the 4.10 ratio will. Lugging an engine is not good for its longevity either.
07-28-2021, 03:57 PM | #24 |
07-28-2021, 04:18 PM | #25 | |
On a typical tractor diesel that's pulling maximum hp, it's at its most efficient when it's running at peak torque rpm. This is why most engine/generator setups that use similar engines are 1800 rpm instead of 900 or 3600. Obviously, the most efficient speeds are different at lower hp output levels. It feels good to lug a big engine, but it's not the best for all the parts involved, nor for fuel consumption.
