Old 03-16-2011, 12:02 PM   #26
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: 8.1
The 8.1L is dimensionally the same as any other big block but the cast aluminum oil pan is much bigger than any other big block and WILL definitely interfere with the stock engine cross-member. I used an ORD high clearance oil pan and spaced up the engine mounts with a piece of plate steel.
ORD HD cross-member
Even with the ORD HD cross-member I felt the need to space the engine mounts upward a tad more to give just a bit more wiggle room.
After spacing. The picture view gives the illusion it is almost touching but in reality you can stick your finger between the oil pan and cross-member. I have been running it like this for two years and a lot of off-roading with no issues or signs of rubbing.
DirtyLarry is offline   Reply With Quote
Old 03-16-2011, 12:12 PM   #27
1tonjimmy
1tonjimmy's Avatar
Re: 8.1
I stand corrected.
1tonjimmy is offline   Reply With Quote
Old 03-16-2011, 10:09 PM   #28
1BadAction
1BadAction's Avatar
Re: 8.1
Excellent, thank you Larry. I had a few hunches about what needed to be done to get one in a K5 but an exact outline of how to do it is GOLD to me. That will make my life much easier when I tear the TBI engine out and drop the 8.1 in.
2010 Basalt Black Porsche Cayenne GTS - Daily driver
1991 2500 Suburban, Black - 454/80E tow monster, soon to go under the knife... Again.
1979 16' Action Marine/"Johnny Cash" Merc Bridgeport Champ Motor - Metalflake Maniac
1BadAction is offline   Reply With Quote
