07-11-2021, 04:24 PM | #1 |
Re-Ring
I would like to re-ring my 71 350 engine. Has any one here pulled the heads and raised the block up some to remove the oil pan to remove the pistons ?
07-12-2021, 10:25 AM | #2 |
Proprietor of Dale's Corner
Re: Re-Ring
In my opinion, it would be a lot easier to pull the engine. It'll be a lot easier to get at everything and clean things properly.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-17-2021, 07:55 PM | #3 |
Re: Re-Ring
You can't just throw a set of rings in without deglazing the bore, and you can't do this with the crank installed because the counter weights will be in the way.
