Old 04-21-2012, 11:52 PM   #1
CRGRS 66
CRGRS 66's Avatar
Looking for advice on suspension updates
I plan to lower my front end 2-1/2 via drop spindles, will be updating to disc and power brakes in the process. Plan to leave the rear end stance as it is.
What I want to learn about is how to go about smoothing out the ride. It would be stupid to re-install the old front springs when I have the front suspension apart. Does it come down to springs and shocks? Truck does not have stabilizer bars either.
Look forward to all of those expert opinions!
Craigerr from
CRGRS 66 is offline   Reply With Quote
Old 04-22-2012, 07:37 AM   #2
brokenspoke
brokenspoke's Avatar
Re: Looking for advice on suspension updates
Changing the spindles will not change ride...sway bar helps a lot leveling on corners...
brokenspoke is offline   Reply With Quote
Old 04-22-2012, 08:03 AM   #3
willyp
willyp's Avatar
Got my stuff from early classic enterprises, she rides like a dream. includes the following:
4/6 Drop Kit (2.5" Drop Spindles, 1.5" Drop Front Coil Springs, 6" Rear Drop Coil Springs, 4 KYB Shock Absorbers, Super Track Bar Kit, Shock Mount Relocator Kit) (Drop Spindles require Disc Brakes)
Front Sway Bar Kit (Utilizes a 1¼-inch diameter bar, Graphite impregnated Polyurethane bushings, your choice of either stock or lowered frame mounts and all necessary grade 8 hardware)
Disk Brake Kit (Complete With Master Cylinder, Proportioning Valve, Brake Lines, Brake Hoses, Calipers, Pads, Rotors, Bearings, Seals, Dust Shields, Dust Caps, Castle Nuts, Slotted Washers, Banjo Bolts, and All necessary Hardware and Brackets)
Rear Drum Brake Rebuild Kit (Highest grade brake components from General Motors and Raybestos to allow you to overhaul your rear brakes with one simple kit, and it comes with everything needed to do the job right)
Power steering kit
http://www.earlyclassic.com/home.aspx
good tech article on the set up i did:
http://www.earlyclassic.com/Tech.asp...9;s+Makeover+I
http://www.earlyclassic.com/Tech.asp...;s+Makeover+II
good luck!
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 04-22-2012, 10:02 PM   #4
CRGRS 66
CRGRS 66's Avatar
Thanks guys, so, as far as improving the ride is the biggest factor good shocks? Are the springs that you find at all of the classic part suppliers equal? Some of these guys offer free shipping on the small stuff if your order is big enough, do any of them cover freight on big stuff if the order is big enough?
Thanks,
Craigerr
Old 04-23-2012, 09:53 PM   #5
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
I got all my stuff from a donor truck including my springs.
The 77 frame I got to pull suspension off of had new springs on the front and some very nice gas shocks.
I wouldn't run without a sway bar or power steering. They both make a world of difference.
It all interchanges with little trouble at all.
The later suspension cross member seems to take a different style spring. At least they were different from the stock 63 units I took out.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
