01-17-2022, 10:53 AM | #1 |
Tires and rear coil springs
Hi all
I have a 65 C10. 6 cylinder 3 speed Someone lowered the rear by heating up the rear coil springs. I’d like to get it back to original height. Also want to put some wider/taller tires on to fill the wheel well gap plus reduce rpm’s a bit while on the highway. Any suggestions on tire size. Thanks. Steve Posted via Mobile Device Last edited by cwcarpenter98; 01-17-2022 at 02:53 PM. Reason: Removed WTB |
01-17-2022, 11:19 AM | #2 |
Re: Tires and rear coil springs
your better off just getting new springs. Most dealers have them, they can also be bought at Summitracing.com or rockauto.com , Most parts houses have them and they are usually in the $100 area. I just looked and if you hurry you can get a set of AC Delco stock springs for $65 at www.rockauto.com Only 1 pair remaining for now. Here is the link but you might have to search for it. It will be under suspension. https://www.rockauto.com/en/catalog/...il+spring,7512 As for tire size. Maybe a 255/70r15. I would check a tire calculator online. Might be to big if you have a stepside. You could run a stock size also of 235/75/15. This is a narrower tire. I have these on my truck all around. These might be the best two pics I have of the tires right now. You could also do a 31 10.50 15 tire if you have the room and a wide enough rim.
I would go and talk with a good tire shop and see what they have and they should work with you on this. Your speedo will be not reading right when you go out of stock size tires. I'm not gong to proof read this so I hope it makes sense.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 01-17-2022 at 11:28 AM. |
01-17-2022, 11:30 AM | #3 | |
Posted via Mobile Device |
01-17-2022, 02:58 PM | #4 | |
01-17-2022, 02:59 PM | #5 |
I had 255/70s on my truck with the first set of 15x8 truck rallies.
I wanted original hubcaps, so switched to a 15x8 nub style hubcap wheel wrapped in 30x9.5s On the springs, I'd probably just go with new unless you can confirm the used set hasn't sagged over the past 50 years. I had a 1/4" think steel plate in my bed for many years, so I think my springs might have some sag in them from that. I haven't removed them yet to check for the free height measurement though You can get any rear spring from 60-72 Edit to add: My truck had 235/75s on the stock 15s when I first bought it. The drum brake wheels wouldn't work with my disc swap, so that's why I changed. You can see in the last pic how much lower the bed sat from that steel plate
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 01-17-2022 at 03:14 PM. Reason: Added pic |
01-17-2022, 03:10 PM | #6 | |
PS - my truck is a fleet side long bed. Thanks Posted via Mobile Device |
01-17-2022, 03:16 PM | #7 |
Moderator
Throw a set of 235 75 15s on there. You should be able to find an inexpensive new or used set. I use them (whitewalls!) on my 65.
01-17-2022, 03:26 PM | #8 | |
01-17-2022, 03:33 PM | #9 | |
205/75-15 = ~27" tall. 235/75-15's @ ~28.8" or 255/70-15's @ ~29" tall.
01-17-2022, 07:16 PM | #10 |
01-17-2022, 07:50 PM | #11 |
Do your new coils come with the bolts and retainers like in this link. If not you’ll need them.
You’ll likely break the bolts off. https://www.brotherstrucks.com/1960-...tinfo/RSRC004/ |
01-18-2022, 08:27 AM | #12 | |
01-18-2022, 12:37 PM | #13 |
On my 65 C10 fleet side stock height, I am using a 275 60 15 on an 8 inch wide steel rim on all 4 corners with no clearance issues. I think the rims have a 4 inch back spacing. The tires are wider and slightly taller than stock. 15 inch tires are getting harder to come by FYI. I will also be adding power steering because of the wider tires.
01-18-2022, 02:55 PM | #14 |
275/60-15 = ~28" tall.
01-28-2022, 10:52 AM | #15 |
I have a pair of stock used springs .
01-31-2022, 10:18 AM | #16 |
02-04-2022, 01:01 PM | #17 |
i put cheap springs on and one was higher than the other,,
got moog springs to fix it.
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle. |
02-04-2022, 01:05 PM | #18 |
02-17-2022, 09:10 PM | #19 | |
02-17-2022, 09:34 PM | #20 |
Falken discontinued the highway version of the wildpeaks, so I went with A/Ts on all 4. Although the mud tires on the back and highway on the front would be a more proper farm truck look, I drive a good bit on 2 lane highways and some interstates, so I prefer to rotate my tires regularly.
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
