01-09-2022, 01:56 PM | #1 |
Can you help ID this GMC hubcap?
I picked up what I though was a 68 gmc c2500 cap today at a swap meet. But the opening measurement is 7 3/4 like the older 1/2 ton caps that I have (55-59). I thought all 3/4 ton caps were 8 3/4? Is this off a van or some sort of odd ball? It measures 10.5 across. Thanks!
Jesse 72 4x4 Sold 59 GMC air ride ls swap |
01-09-2022, 02:11 PM | #2 |
Re: Can you help ID this GMC hubcap?
Sorry i had an issue with the images, here they are.
01-09-2022, 02:20 PM | #3 |
Appears to be the "clip" style, so opening is smaller.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
01-09-2022, 02:52 PM | #4 |
I know its clip style, but i though they only made 3/4 ton caps in clip style with a 8 3/4 opening. Did they make 1/2 ton clip style caps?
01-09-2022, 03:17 PM | #5 | |
This link is of the 60-66 caps but I am sure it is the same idea. http://67-72chevytrucks.com/vboard/s...d.php?t=702839
01-09-2022, 03:18 PM | #6 |
Yes they made both nub and clip style caps for half ton.
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Project "Little Sister" (70 c10 blue original paint refresh) Project "C10 Fever" (68 factory black 396 swb) Project "Blue Bomb" (70 c30 blue original paint refresh) Project "Vitamin C" (71 c10 orange original paint refresh) |
01-10-2022, 10:37 PM | #7 |
On 1/2t it depended on the type of wheel. Some optional wheels still took clips type because they date back to before nub types.
01-20-2022, 02:24 PM | #8 |
Thanks for the help guys. I did not realize they make 1/2 ton clip style wheels in 68. Its a cool wall hanger at the very least!
01-20-2022, 07:27 PM | #9 |
The standard 15" 6-lug wheels had nubs, but if optional tires in larger diameter were ordered they would be the same wheels used dating back to the clip days. So GM adapted the caps to fit. You can see a lot more meat between the cap itself and the inner circle. On an 8-lug cap, which all were clip-type, you would see much less meat since the 8-lug pattern is larger diameter
