Old 07-07-2015, 07:23 PM   #1
papsoldblue72
papsoldblue72's Avatar
Question Header help
I need some different headers..... What kind???? I don't know please help.... I have a 72 long bed with a 350 and angle plug heads.... Which is where my problem comes in.... The headers I bought from summit don't fit.... The driver side number 3 cylinder hits the sparkplug.... I have looked into header plugs but they are only short on the threaded part not the porcelain part..... "Why you make header plugs to clear your headers and the outside part not be shorter I'll never know..." If anyone has some they want to get rid of or knows someone that does please let me know .... I need some but I don't want spend a fortune on them...... Thanks in advance....
It's been a long time coming... It's time to get it done..
papsoldblue72 is offline   Reply With Quote
Old 07-07-2015, 07:42 PM   #2
geezer#99
geezer#99's Avatar
Re: Header help
Accel makes shorty plugs.
Short on the porcelain.
IIRC NGk does too.
http://www.summitracing.com/int/sear...spark-plug/yes
geezer#99 is online now   Reply With Quote
Old 07-08-2015, 01:15 AM   #3
papsoldblue72
Re: Header help
IIRC NGk does too.
Sorry geezer#99 I ordered these and picked them up at the auto parts store and laid them side by side and there is no difference in the length of the porcelain portion of the plug... unless I am running the wrong plug... I am running procomp heads. So I called them and the plug they recommended is the one I am running..... I can't remember the number....
Old 07-08-2015, 12:05 PM   #4
Fitz
Re: Header help
When I bought the engine for my truck there were fewer than 500 of that engine that had been sold by GM. It was unusual block with a different head design and no one I called knew what headers to use. I did know a header manufacturer that had an excellent tech line, so I called them. They had a set that would fit and I have not had any problems with them. Ever. Call the Sanderson Headers tech line, tell them what motor and heads you are running and if there is a set that fits that combo they will know about it.
Fitz is offline   Reply With Quote
Old 07-08-2015, 12:29 PM   #5
papsoldblue72
Re: Header help
Thanks Fitz I will call them but I was really looking for something like a cheap fix...
Old 07-08-2015, 08:33 PM   #6
Z10
Z10's Avatar
Re: Header help
Sanderson CC11. Installed on my 72 GMC with ZZ4 & angle plugs.
More photos on my build thread.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
1972 c-10 pick up, headers, help needed
