03-19-2024, 09:08 AM | #3651 |
Re: PO has me PO'd
#2x3/4" self drill screw
Works better if you predrilled 17108533671323610477507928785123 by [url=https://www.flickr.com/photos/97391199@N06
03-21-2024, 11:59 AM | #3652 |
Re: PO has me PO'd
17110364857403009535035745668611 by [url=https://www.flickr.com/photos/97391199@N06
Chuck in a chuck
03-21-2024, 12:01 PM | #3653 |
Re: PO has me PO'd
17110365478576902649425331948102 by [url=https://www.flickr.com/photos/97391199@N06
03-22-2024, 09:45 AM | #3654 |
Re: PO has me PO'd
The screws are so small that I have to use my hymastats
17111149264951999854906294122015 by [url=https://www.flickr.com/photos/97391199@N06
03-23-2024, 10:11 AM | #3655 |
Re: PO has me PO'd
Oversize hole in patch panel, draws sheet metal tightly
17112028247662920689203766817748 by [url=https://www.flickr.com/photos/97391199@N06
03-25-2024, 11:50 AM | #3656 |
Re: PO has me PO'd
If you're not getting spiraling pig tails, use more lubricant saves on drill bits
17113814976342150880044317980103 by [url=https://www.flickr.com/photos/97391199@N06
03-27-2024, 08:39 AM | #3657 |
Re: PO has me PO'd
17115430442306797632180518517808 by [url=https://www.flickr.com/photos/97391199@N06
03-27-2024, 08:42 AM | #3658 |
Re: PO has me PO'd
17115429655647856498034021472742 by [url=https://www.flickr.com/photos/97391199@N06
In Milwaukee s infinite wisdom they changed the shaft size to 1/2-20, standard shaft for a 3/8 chuch was 3/8-24 ao now I have to make an adapter or put the chuck on my Dewalt Found this out after I watched the video on chuck removal
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-28-2024 at 11:13 AM. |
03-31-2024, 08:45 AM | #3659 |
Re: PO has me PO'd
Couldn't figure out a way to get a straight cut on the flange, until I saw the replicator in my toolbox
1711889053472433638631067172882 by [url=https://www.flickr.com/photos/97391199@N06
04-03-2024, 07:09 PM | #3660 |
Re: PO has me PO'd
Picked up my application gun and panel bond
17121855599823936406119597150181 by [url=https://www.flickr.com/photos/97391199@N06
04-03-2024, 07:46 PM | #3661 |
Re: PO has me PO'd
Things are about to get sticky
04-09-2024, 08:47 AM | #3662 |
Re: PO has me PO'd
Just hope it's not all over my hands
On another note don't like the way this NOS trim is lining up. Rather not screw up nice trim I'll look for some beater 72 trim, I can still do the 2 tone paint 1712666401661221993376299322067 by [url=https://www.flickr.com/photos/97391199@N06
04-09-2024, 06:03 PM | #3663 |
Re: PO has me PO'd
I have used that panel glue, bonds real well
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-12-2024, 09:03 AM | #3664 |
Re: PO has me PO'd
Jesse, did you clamp it or screw it
SNAFOWLEDU 17129268232473391299823221734226 by [url=https://www.flickr.com/photos/97391199@N06
05-12-2024, 07:53 AM | #3665 |
Re: PO has me PO'd
17155145783528792159940437182032 by [url=https://www.flickr.com/photos/97391199@N06
05-13-2024, 09:07 AM | #3666 |
Re: PO has me PO'd
That looks pretty good
Time for some zip screws Cut some of the bolt in flange back to get a better fit to the patch panel 17156054833798123115454248895876 by [url=https://www.flickr.com/photos/97391199@N06
05-18-2024, 10:00 AM | #3667 |
Re: PO has me PO'd
Lesson learned contain all the tools needed for a particular project in a box when you get back to it you
don't have to search your toolbox to finish project And you don't have to pickup tools fallen off work Station 1716040296358659630810166791235 by [url=https://www.flickr.com/photos/97391199@N06
Today, 08:57 AM | #3668 |
Re: PO has me PO'd
Today, 09:01 AM | #3669 |
Re: PO has me PO'd
Back lower corner off,pie cut
17162963257043339189953605460141 by [url=https://www.flickr.com/photos/97391199@N06
