03-13-2008, 02:50 AM | #26 |
Re: sway bar bracket????
03-13-2008, 10:02 AM | #27 |
I didn't. Mine were bolted directly to the frame w/5+" of front drop. I'm not sure how it will be now w/a Dropmember up front (haven't had the a-arms installed long enough to figure it all out).
03-14-2008, 08:03 AM | #28 |
A guy with a truck
When you figure out the swaybar, let us know. It looks like you could use the stock outer hole and drill another. That's w/stock arms- if you're using ARTs, I dunno...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-14-2008, 08:05 AM | #29 |
I am using ART's.
12-08-2013, 11:30 PM | #30 |
Thanks for all who posted, helped me with my search! Looks like ill be cutting my stockers and flipping them around like redrat
