08-05-2022, 06:29 PM | #1 |
73 Jimmy OfferUp Find
Hello. I’m not sure if there is a Post Your Craigslist Find for 73-87, but I wasn’t able to find one
Anyway, I picked up this 1973 Jimmy from OfferUp. I was told it spent a lot of years in the Southern California desert, which accounts for all the paint fading and toasted interior. I picked it up for $7,500 which I know is a bit much considering the roughness. I justified it in my mind because it’s a running driving full convertible (and smog exempt in CA) with a clean title, solid floors and rockers. For some reason I’m having problems adding pictures right now. I’ll try and add them in a bit -Vinnie Posted via Mobile Device |
08-05-2022, 06:37 PM | #2 |
Re: 73 Jimmy OfferUp Find
Looking forward to seeing the pictures.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
08-05-2022, 08:18 PM | #3 |
..I still can’t load the pictures.
Anyway the truck is still on OfferUp if you want to see the pictures. The location of Santa Ana Ca. The listing is under 1973 GMC Jimmy. It’s a badly faded orange color with white top. This is turning into a bit of a wild goose chase. Sorry about that! Posted via Mobile Device |
08-06-2022, 03:05 PM | #4 | |
08-07-2022, 08:21 AM | #5 |
That was a fair deal I would say. They’re getting harder to find and I love that color. I’m considering a 74’ in worse condition for more money right now.
08-07-2022, 04:27 PM | #6 | |
Thanks for the feedback. That makes me feel a little better about the whole deal. Posted via Mobile Device |
08-08-2022, 07:31 AM | #7 |
It looks very rust free. FWIW I paid 9k for a “rust free” blazer that wasn’t rust free, and barely ran…I think you got a steal
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD 73 k5 gm crate 350-265 / sm465 / np205 3.73 posi |
08-08-2022, 09:34 PM | #8 |
Active Member
You got a good deal. I bought a 74 blazer, good amount of rust, missing part of original interior, 5k. Then got a 73 jimmy, same amount of rust, missing most of original interior and engine for 3k
08-11-2022, 08:40 PM | #9 | |
Can anyone tell me what these plugs are for? It looks like they were added to the rear corners of the truck, along with a bracket wired with threads. Like the base for an antenna? If so, what type? Sorry, I’m pretty clueless about some of these things. Also, why did they add this plug to the front of the truck. Wouldn’t this go at the rear for towing? Thanks Vinnie Posted via Mobile Device |
08-11-2022, 08:42 PM | #10 | |
Here’s the front plug Posted via Mobile Device |
08-11-2022, 08:46 PM | #11 | |
And here’s a picture of some sort of air horn setup. Posted via Mobile Device |
08-11-2022, 09:23 PM | #12 |
Active Member
Looks like trailer wiring plug at front and rear. The one at the rear is just where they chose to mount it, the one at the front is probably for being towed behind an rv
08-12-2022, 11:57 AM | #13 |
08-12-2022, 12:58 PM | #14 |
Nice Find! Is there a SPID to be found?
MusicMan70 1961 GMC Suburban |
08-12-2022, 06:31 PM | #15 |
08-12-2022, 08:11 PM | #16 |
Just here to tinker
The finned unit looks like a battery isolator. Perhaps this was towed behind an RV and the RV would charge the battery in the jimmy. Hence the plug in the grill has more pins than the plugs in the rear.
The battery isolator would’ve enabled the battery to be charged without also being drained by the RV when the engines were off. If that makes sense.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
08-12-2022, 08:20 PM | #17 | |
