02-17-2021, 08:05 PM | #1 |
Cold Climate Package - special heater
What makes the heater and defroster special in the cold climate package? Is a larger fan used?
K81 - Cold Climate Package (Including Special Insulation, 66 Amp Alternator, Special Heater & Defroster, Engine Block Heater, HD Battery.) |
02-19-2021, 09:59 AM | #2 |
Re: Cold Climate Package - special heater
bigger heater core I think
02-19-2021, 10:44 AM | #3 |
The only thing I have found for K81 is the larger alternator (66 AMP). It may vary a little depending on the year of the truck, but that was the only code description I have found.
02-19-2021, 08:45 PM | #4 |
If someone knows how to source the K81 heater core, I'd be happy to know about it, particularly if it can be retrofitted to a non-K81 truck.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
02-20-2021, 04:13 AM | #5 |
I’m not sure if your unit was on a A/C unit or none A/C unit that it came from.?
I had a cold area heater box that had an extra flap that could be opened at feet heat. ( 1975 350 A/T TH350 none A/C unit) 37AMP/43AMP. If it were a A/C unit it may have had a VAC access climate controls with one or two cables. Those would have the higher amp ALT. as the 66AMP.( might have had a amped up blower) Or just manual cable only unit with A/C not to common after 80. Not sure if this will help or not.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
02-20-2021, 06:08 AM | #6 | |
How do you open the extra flap? I've always just used the controls in the dash. |
02-24-2021, 10:53 PM | #7 | |
Is your switch a 4 position switch? I have an 81-82 Diesel parts truck with a full firewall insulation in the engine compartment. It has no glove box door so no codes. Im guessing the insulation is to keep the clatter out but it should keep the heat in the cab as well, I would think. The L&R sides of the windshield on my 81 K30 will freeze into a thick icy mess if I have the defroster on while it is snowing and going down the road. The only way to be able to drive is to keep the windshield cold. I am switching to an AC cab but I want to be able to fry bacon in there.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
09-23-2021, 08:47 PM | #8 | |
Is the 4 position fan switch only on the cold climate packages? |
09-24-2021, 10:48 AM | #9 |
Following, any pictures?
02-20-2021, 10:49 AM | #10 |
Pretty interesting. I live in a cold climate and this is the first I have heard of this option. I have never seen in on any of my SPID's either. My 76 GMC is from North Carolina and the heat is so hot it takes my breath away.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
02-21-2021, 09:58 PM | #11 |
There is a cable that runs of one of the leavers. It's nice on the cold night in fall and winter to warm up the floor take some of the cool out of the floor area this is only on the None A/C units. My 84 did not have it the 75 and the 77 all three where made in Canada & None A/C units. You really feel the difference on a good highway drive when it cold.
02-22-2021, 04:12 AM | #12 | |
I have no ac and the cold climate package. I do have a floor heater. |
02-22-2021, 05:58 AM | #13 |
Some info here on it
http://www.chuckschevytruckpages.com...s_1973-87.html K81 - Cold Climate Package (Including Special Insulation, 66 Amp Alternator, Special Heater & Defroster, Engine Block Heater, HD Battery.)
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
02-22-2021, 06:02 AM | #14 |
Also info here about it.
It is sideways on page 13 https://www.gmheritagecenter.com/doc...t-Suburban.pdf
02-22-2021, 12:18 PM | #15 |
My 78 was non A/C. When the heater motor went I replaced it with a motor for an A/C unit. You could cook pizza on the dash. It put out crazy heat.
02-23-2021, 02:11 AM | #16 |
02-23-2021, 01:31 PM | #17 |
^ Sounds like it put out more heat with the upgrade fan. Good tip as my truck never feels like it heats up enough.
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ |
02-23-2021, 03:13 PM | #18 |
Yes.…. Crazy heat with the new larger A/C motor.
02-23-2021, 06:07 PM | #19 |
02-24-2021, 04:50 AM | #20 |
Up here in Canada the heavy duty heater option wo/AC consisted of and extra position on blower switch low- med1- med2 -high. there was an extra wire to the resistor and and it was shaped similar to the a/c resistor with the extra circuit for almost no resistance so the blower motor blew faster than normal and it was a little bigger armature with the cooling tube added to it .
It was easy to retrofit because the blower wiring harness was separate but it still plugged in to the main harness at the blower switch (brown) and at the blower box you could drill the hole for the cooling hose and enlarge the hole for the resistor. Easy way to tell HD or not , is the extra position at blower switch or different shape resistor at box. Parts- Blower box (or modify) Blower motor Blower cooling tube Cooling tube to box plastic adapter + screw 4 position resistor 4/wire wiring harness to switch Extra position blower switch
100:1 low gear! |
02-23-2021, 06:02 PM | #21 |
I only use my blower for a couple minutes then keep it on low the rest of the day with temp in the middle. Any higher than that and I literally can't breath.
