05-20-2021, 12:05 PM | #76 |
Moderator
Re: 1965, L6 292 Engine Power Steering Pump Set-Up
Those two studs with the nuts on them hold the pump into the reservoir.
05-20-2021, 12:33 PM | #77 | |
I think I’m going to just cut a slot in my bracket.
1963 C20, small window, long bed 292, 4-speed |
05-25-2021, 11:24 PM | #78 |
Got the steering connected and pump installed, started it up and no leaks. So far!
05-27-2021, 07:46 PM | #79 |
Just got the wheels on the ground and the steering is very difficult to turn. Just parked, but still, really hard. Most PS you can turn the wheel pretty easy.
EDIT: It helps if you bleed the air out...
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 05-27-2021 at 11:56 PM. |
