05-22-2021, 07:55 AM | #26 |
Carpe manana
Re: WTB: U-bolt plates for 14 bolt rear axle
I believe these are Ruff Stuff. Hoping to ditch the OE plates but holes would be helpful. Guy I bought these from told me he’s seen full thickness rust out of axle tubes from the OE plate design.
05-24-2021, 07:50 PM | #27 |
I have these. Measurement across the opening is 3.25", is that the right size?
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
05-24-2021, 08:23 PM | #28 |
Carpe manana
Thanks. Those look good might be just short though. The axle tube OD is 3.375”.
05-24-2021, 08:35 PM | #29 |
Almost wonder if you need this style? Came off a 77 dually with the Dana 70hd axle. Part number 327224. Measures 3.75" and had the factory rear sway bar.
05-24-2021, 08:49 PM | #30 |
Carpe manana
Brian thanks. Here’s what mine currently looks like. Pretty sure it’s that first style - like a bowl designed to store water. I learned the post 99 14 bolt tubes went to a 3.5” diameter from 3.375”. I’m optimistic the plates I have will work for the long haul. I’ll coat them with POR-15 and a top coat ahead of install.
05-24-2021, 09:36 PM | #31 |
holy smokes - and new u bolts stat!
crazy how such a nice rig can have such a dirty little secret good luck sizing up new hardware and I agree on the drain hole idea.. and keep the mud and road salt (if applicable) washed out of there as much as possible..
I started out with nothing - and I still have most of it |
05-24-2021, 10:00 PM | #32 | |
Carpe manana
The new plates I have will flip the U bolts so no more puddle collecting.
05-25-2021, 07:18 AM | #33 |
Proprietor of Dale's Corner
I would replace the spring center bolts too...
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-25-2021, 07:30 AM | #34 |
Carpe manana
Thanks Dale - I’ll ensure those are replaced if not solid. I also figured I might as well replace the 20 yo shocks and found the same OEM Bilstein examples. Hope to get many years more service from the truck.
05-25-2021, 07:41 AM | #35 |
Nice! The shocks look great.
05-25-2021, 01:53 PM | #36 |
great shocks! I expect nothing less from the king of OEM
