02-01-2023, 02:50 PM | #1 |
Active Member
10.5 FF 14 Bolt Limited Slip
I am currently starting a rebuild of a 1978 GMC K25 that spent the majority of it's life in the desert SW. It was run hard and put away wet so to speak! The engine, trans and t-case were all replaced at some point, and the replacements were all cracked so most of the driveline went to scrap. I am parting out a 2003 Silverado 2500HD and am considering putting the 8100 Vortec (496) in this truck as I have a Dana 60 front to replace the Dana 44 front that came on it. The 10.5" 14-bolt rear should be more than adequate for what I will be doing but I would like to put some type of Limited Slip in the 14-bolt to replace the GovLoc (worn out I might add) that is in it.
I am wondering what experience some have had with aftermarket LSD carriers. I do not need a Detroit Locker for what I will be doing but will need added traction that an open diff cannot deliver. Plus the 496 has way too much torque, if there really is such a thing! Thanks in advance. Tom |
02-02-2023, 03:05 PM | #2 |
Re: 10.5 FF 14 Bolt Limited Slip
Tru-trac or more aggressive approach is a detroit locker
02-02-2023, 09:35 PM | #3 |
Trutrac X2
02-03-2023, 08:01 AM | #4 |
Trutracs are great. I wasn't aware that they made them for the 14 bolt. If money was no object I would go E Locker or Air locker.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
02-03-2023, 08:05 AM | #5 |
Active Member
Thanks! I have not blown a factory GovLoc but have witnessed other do it, including my son (I told him not to drag race my truck)! I have heard good things about the TruTrac and sounds like a good route to go!
02-03-2023, 08:39 AM | #6 |
Personally I like the Govloc. It performs great in stock vehicles. I've only seen one broken one in a 10.5"/11.5" and it was thoroughly abused. It's hard to tell if it's worn out without taking it apart.
02-03-2023, 05:53 PM | #7 |
I blew a Gov-Loc right through the case just driving at freeway speed. But that was on a 12 bolt. I think the design on a 14 bolt is a lot stronger.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
02-07-2023, 03:32 PM | #8 |
Trutrac is going in the 9.5" 14bolt I am putting in my '65 C10.
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
02-08-2023, 02:06 AM | #9 |
Have had TrueTracks front and rear for several years in a Toyota and recently added one to the front of my Chevy. Very happy with them. Can’t tell they are in there except when I don’t get stuck. Also no silly clutch packs to wear out. Same basic design as used on military Hummve’s, so that should say something.
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
