Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 06-10-2021, 11:24 AM   #1
D13
D13's Avatar
Small part painting gun?
I'm starting to work on my trucks again. I have a lot of brackets, mounts, braces, etc that I would like to clean up and paint in black epoxy. I have limited time and usually get no more than a couple done at a time. Here in MI, if you don't get paint on it quick, it will rust, and rustoleum primer ain't what it used to be. Problem is, I need like 1/4 - 1/2 cup mixed paint, and I don't really have a good system for that. Air brush is a little too small for some of the bigger brackets. My touch up gun is an old siphon and cleaning it is time consuming and expensive. Best idea I've come up with so far is HF touch up HVLP and finding a small capacity cup system for it. Anyone got a better idea, or know what cup system fits?
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 06-10-2021, 11:35 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Small part painting gun?
I've been very impressed with the black widow I got from hf..I know it's full sized
The other gun I dropped and broke was the Eastwood concours edition..it was a 2 gun setup, 1 hlvp fullsize and a hlvp touch up gun...I'm very impressed with the little touchupper...I used it a good bit for my smalls..
The biggest issue I have with the small gun is your limited on tip size choices for what I have
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-10-2021, 01:00 PM   #3
tinydb84
tinydb84's Avatar
I am really tempted to get that black widow gun. Do you notice the difference between the HTE and HVLP?
To the original question-I bought a small gun off Amazon and it was so amazing. Then it broke (after a ton of use) when I bought it again it was a different manufacturer and was crap. I use a harbor freight purple gun now-even for the small stuff.
You can get the little aerosol cans (Preval is the brand) with the little glass jars on the bottom from most hardware stores. I have used them in a pinch. They work well enough for small stuff but they get expensive for what they are.
David
Instagram: myfabguy
Old 06-10-2021, 01:32 PM   #4
mongocanfly
Post Whore
David..I couldn't tell much difference myself..hard to find a bad review on it
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-14-2021, 12:33 PM   #5
tinydb84
tinydb84's Avatar
Thanks Mongo. I might pick it up when I get around to spraying something other than primer. I just cant justify buying a $400-500 gun when I barely use it.
David
Instagram: myfabguy
Old 06-15-2021, 01:59 PM   #6
JJH Jimmy
JJH Jimmy's Avatar
I bought this kit from Harbor Freight to spray primer and it works really good. Both the guns are easy to clean compared to the purple guns. I have sprayed both epoxy and 2K in the full-size and sprayed epoxy, base and clear in the detail gun. Spraying small parts with the detail gun will save you a ton of material and right now they are both on sale for $35.00!
https://www.harborfreight.com/profes...kit-94572.html
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
