10-25-2021, 11:05 AM | #1 |
progression ignition
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
10-25-2021, 11:26 AM | #2 |
Re: progression ignition
Interesting
George |
10-25-2021, 11:54 AM | #3 |
Mr. Cheyenne
Funny you ask, I just installed mine this weekend. Went in like a charm (other than me putting my plugs on off by one). She fired up perfectly at 10 BTDC and I tighten the distributor down. Even before putting in my 1st table she idle better than ever before.
After that, I put in my basic default data in the iPhone app and submitted my 1st table. I have more power across the board and I can keep my idle around 750. When I put it into gear and have AC on, the distributor gives a bit more timing. So I been able to shave 100 RPMs or so on my idle because of that. So in summary - I love it. For the record, I got the Black / Female one.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
10-25-2021, 12:48 PM | #4 |
good enough for me I am sold
10-25-2021, 12:53 PM | #5 | ||
Mr. Cheyenne
if you have any questions for progression ignition, they have answered pretty quickly. Somewhere I read they were in California but I guess they are in Florida now. So I get responses in the early morning here in Texas.
My last question to them, that they answered earlier today was: Quote:
10-25-2021, 01:05 PM | #6 |
Mr. Cheyenne
Oh, my 72 C10 setup:
SBC 350 (Stock-ish) 72 Qjet Carb (rebuilt by Cliff's High Performance). Automatic TH350 Power Brakes & Steering A/C (converted r134a) 3.07 Open rear end Gauge cluster was upgraded to have a Tach, which still coming off the coil. So no problems with the tach! I am using full manifold off the intake tree behind the carb to go into the distributor - I had to split it off from the client control vacuum reservoir. This old 72 Qjet only has the one full vacuum port in the front for PCV Valve & EEC charcoal canister. I wished that vacuum port on the distributor was pointed 90 degrees and not straight down - its a right PITA to get the hose connected!
10-25-2021, 03:55 PM | #7 | |
You could tee into the choke pull off hose instead. You got a pic of the front of your carb? |
10-26-2021, 08:30 AM | #8 | |
You're really making me think about this too... Once I get off my a** and use Cliff's rebuild kit on my QJet, that dizzy might just have to be next... a little pricey but it sure sounds like a big improvement.
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor |
10-25-2021, 04:01 PM | #9 |
Mr. Cheyenne
there are other ports but they aren't FULL vacuum. The progression ignition requires full vacuum, full stop.
The one on the side by the choke, I have always assumed was ported too. I suppose I should hook up my vacuum gauge to check it. My '78 Qjet had more ports, one of which was full vacuum on the front (not including the normal one for PCV). Edit: I suppose I should check each capped port with my gauge, so I am not spouting off lies!
10-25-2021, 06:17 PM | #10 |
The bottom right one (choke side) on the front should be a manifold vacuum.
You're really making think I need to pull the trigger. I've been mulling it over for months.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-25-2021, 06:45 PM | #11 |
Mr. Cheyenne
Color me wrong for assuming the two ports on the passenger side (front top and side) were ported. I guess the only ported one is the diver's side that you see capped in my attached photo.
Though to me it seemed the passenger top had a bit of a stronger vacuum, so I connected this to the progression ignition vacuum port. Gee, I feel stupid as I should have connected all the ports to my vacuum gauge months ago. Edit: This is what I have decuded with my gauge and how the lines are connected.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 10-25-2021 at 07:02 PM. |
10-25-2021, 06:56 PM | #12 |
What’s the vac used for on the distributor?
For a vac signal maybe! |
10-25-2021, 09:06 PM | #13 |
It's actually a MAP sensor.
10-26-2021, 09:11 AM | #14 |
laying low
We've all gotten used to carrying a spare module for our GM HEI units. That's usually all that fails with them and it's widely available.
What would be the failure items, beyond cap and rotor, with this unit and are replacement parts readily available locally or will the unit have to be returned to them for repair?
10-26-2021, 10:57 AM | #15 | ||
Mr. Cheyenne
10-26-2021, 01:00 PM | #16 | ||
Mr. Cheyenne
10-25-2021, 07:23 PM | #17 |
Mr. Cheyenne
I had vacuum connected before, just off the intake manifold's two port tee (one to TH350 and the other to climate control reservoir).
I am much happier with this setup for sure. Nice to learn stuff properly, which is what I get for assuming sh*t! But I swear I read any vacuum port on the top / middle of the carburetor was ported. PS to bigmac73 Sorry, seems I kind of hijacked your thread - i didn't mean to do that.
10-26-2021, 12:32 PM | #18 |
PS to bigmac73
Sorry, seems I kind of hijacked your thread - i didn't mean to do that.[/QUOTE] no sweat keep the info coming
10-26-2021, 08:38 AM | #19 |
Mr. Cheyenne
I asked that very question to progression ignition, they told me I could keep using my Pertronix Flamethrower Coil & Wires! So it was just dropping in the Progression's distributor and done!
I had bought Pertronix before over Progression because I was weary about it. Though now I have the Pertronix Flamethrower for backup!
10-26-2021, 09:18 AM | #20 |
Mr. Cheyenne
On their site, no parts listed for module replacements. I have sent in a query about this topic of replacement parts (yesterday). Though I assume it is just the module....
As soon as I hear back on that answer, I'll report back here!
10-26-2021, 09:54 AM | #21 |
That looks pretty cool! Wonder if you could use that on a Holley Sniper, in place of the Hyperspark? Or would that be overkill?
12-29-2021, 11:48 AM | #22 |
well i pulled the plug and have a new one sitting on the work bench in the garage
12-29-2021, 11:59 AM | #23 |
If you have time please do a write up on installation and tuning. I have been looking at one of these since the thread started. Thanks, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
12-29-2021, 01:31 PM | #24 | |
Mr. Cheyenne
I haven't had any issues and love the darn thing. When out shopping for Christmas I used the lockout. Not on one of our trucks but applies: https://www.youtube.com/watch?v=HeihiAE1zJg
12-30-2021, 11:57 AM | #25 | |
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd Last edited by raggedjim; 12-30-2021 at 12:07 PM. |
