Old 10-18-2023, 11:16 AM   #76
A1971Blazer
A1971Blazer's Avatar
Re: Temperature sensor modification
Originally Posted by Clyde65 View Post
I have aftermarket guages, Autometer, can this be done on a 2258 sender??
Thanks!!
I looked at the sender you mentioned, it's specified to be a 1/8"-NPT which is obviously much smaller that either the original ½"-NPT or the modified 3/8:-NPT.
It looks like all you will need is just a reducer bushing to make it function.
Is this it?
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 10-18-2023, 01:14 PM   #77
Clyde65
Clyde65's Avatar
Yes sir, that’s it.
I currently have an adapter but thought maybe I could get it to reach in there deeper. I heard about you and what your doing from Captn Fab so wanted to see if you could help.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-18-2023, 01:40 PM   #78
A1971Blazer
Yes sir, that’s it.
Thanks for reaching out. I understand about wanting to get the sender further into the coolant flow.
It may be possible to modify the adapter bushing in a way that would allow the sender to go in further.
Putting a counter bore in the bushing and tapping it deeper might get the result you're looking for, then again it may read correctly just as it is without any modification.
I would try it to see if you get the correct reading. The aftermarket gauge might be better than the factory one.
1967 C10 Step side
1968 C10 Step side
Old 11-29-2023, 03:38 PM   #79
wwboater
PM sent for payment info. Thanks
wwboater is offline   Reply With Quote
Old 11-30-2023, 08:42 AM   #80
A1971Blazer
Will go out today 11/30/23...tracking info sent via PM
Thank you!
1967 C10 Step side
1968 C10 Step side
