01-09-2007, 11:10 AM | #1 |
rear blazer seat in sideways?
I was looking at purchacing a 70 blazer cst 4x4 85,000 original miles with tach dash. What I noticed was the rear seat was mounted sideways ( on the drivers side) and the rear tire was located behind the drivers seat. It looked all factory to me, Any Ideas?
01-09-2007, 12:29 PM | #2 |
SKINNY TIRES RULE!
Re: rear blazer seat in sideways?
If it has the spare factory behind the driver's seat, the rig didn't come with a rear seat. check the build sheet on the glove box - it should be listed. As for mounting the seat sideways, it sounds like a bad idea. I'd look to see if they welded in some supports or just drilled holes through the thin bed metal. If the rig came with a rear seat factory, there should be some mounting points in the bed welded in place with threaded inserts - two in the front and 4 in the back (two of the four rear locations could be for seat belt bolts depending on how it was built.)
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
01-09-2007, 01:36 PM | #3 |
The LuvShack Garage
At work now, but I have a detailed floor pic I could post later if you need it
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
01-09-2007, 01:40 PM | #4 |
There was no mounting hole in the standard areas, not sure about how the current ( sideways) location is mounted. Thanks
01-09-2007, 01:40 PM | #5 |
GQ: send the floor pic...thanks
01-10-2007, 08:49 PM | #6 |
The LuvShack Garage
Here ya go, BTW the No damn idea is the jack hold down bracket holes
