02-08-2011, 09:37 PM | #1 |
Corner Speaker Install for 67-72 Pickup ?
Anyone have pictures and some tips for installing 6x9 speakers in the cab corner on a 67-72 pickup? I moved the tank to under the bed couple years ago and am now thinking I need to take advantage of the space and install some decent speakers. Don't want to go the sub boxes route, want to have the available space behind the seat for storage so am thinking of mounting speakers in the corner, just not sure what would work best.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
02-09-2011, 03:37 PM | #2 |
GMC's n H.D.'s too!
Re: Corner Speaker Install for 67-72 Pickup ?
I came across this post a while back, and bookmarked it, so I could try to come up with something like it for my daughters truck, and ultimately for my truck.
It might give you some ideas. http://67-72chevytrucks.com/vboard/s...d.php?t=287987 |
02-09-2011, 05:05 PM | #3 |
I would do it just like that, only out of wood. I am putting a pair of 6.5" mids just above that location, but I am doing a full rack across the back.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
02-10-2011, 10:58 AM | #4 |
chevy_man5, I contacted bigblock73 about those cab corner mounts but as produced they will not fit a 67-72 cab. Gives me an idea about building some of my own using MDF chip board or such. Just looking for other options. Thanks for the reply.
02-10-2011, 11:27 AM | #5 |
GMC's n H.D.'s too!
No problem Ironhorse.
I was planning on using them as an idea base, for making our own as well, either out of metal or MDF. I was thinking I would put them in the bottom of the corner, and angle them up, towards the center of the cab for better sound, instead of facing straight out. Then make some kind of filler to go above them to seal off the opening. We are a ways from that point, but there are SOOOOO many ideas flying around in my head. Good Luck!! Make sure to post pictures of what you come up with, maybe inspire someone else too! |
03-12-2011, 07:12 PM | #6 |
yeller
I will have 67-72 brackets ready to go by spring, if you guys are still interested. I can make them with 6x9 cutouts, or leave them blank so the owner can cut for whatever size he or she wishes.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
03-12-2011, 07:49 PM | #7 |
subscribed, like to see those for the 67-72
72 SWB - Porterbuilt Front/Rear, 22's, 496bbc - "Outkast" 68 Stepside - Porterbuilt Coilover Chassis, 22's, LS3 - "Badfinger" |
03-14-2011, 05:58 PM | #8 |
Jeff, I would be interested in your 67-72 corner brackets. Do you plan on making them to mount at the upper or lower portion of the corner opening? I moved my in-the-cab tank a couple years ago to under the bed and think that along with a good pair of speakers mounted to the factory front speaker area would be a good set up. Keep us posted on your progress.
03-18-2011, 02:55 PM | #9 |
Subscribed. Might be interested as well.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
03-19-2011, 12:51 AM | #10 |
yeller
They will run from the floor up to about were the door latch assembly is bolted to the cab...so they will be taller than the 73-87 style. They need to run to the floor for mounting purposes...not many places to bolt them to on the 67-72's. They will clean up the corner of the cab nicely...and the speaker itself will be up towards the top.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 03-19-2011 at 12:51 AM. |
03-20-2011, 06:54 AM | #11 |
Will be looking forward to seeing them when you get them built. Sounds good.
03-21-2011, 10:28 AM | #12 |
I will be interested in them! fo sho!
It's not rust...It's character! |
03-23-2011, 12:54 AM | #13 |
me too
71 GMC 1500 LWB |
03-28-2011, 08:04 AM | #14 |
"THE GREEN GOBLIN"
Subscribed as well for the 67-72's
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
04-09-2011, 04:34 PM | #15 |
A guy with a truck
In. Any Progress? It's spring
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-10-2011, 11:06 PM | #16 |
yeller
Yes and no, sold a spare cab I had in the shop, now I have room for the 67-72 cab. I should have it moved in this week so I can finish up the design work, then I'll get it in CAD, cut, bent and mocked up.
04-17-2011, 10:47 PM | #17 |
Eat, Sleep, Drive a Chevy
subscribed, sounds cool
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
04-18-2011, 01:48 AM | #18 |
04-27-2011, 08:39 AM | #19 |
Just checking in for a progress report.
05-02-2011, 11:04 AM | #20 |
I like those corner brackets.I used rod doors back panel cover covered it in vinyl and cut out speaker holes.
05-05-2011, 12:50 PM | #21 |
yeller
Sorry guys, been tied up with a house project...please be patient, I will get them done soon, I promise.
05-06-2011, 10:15 AM | #22 |
Interested and subscribed
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
06-06-2011, 01:24 PM | #23 |
Interested
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
06-11-2011, 06:37 PM | #24 |
suscribed
06-23-2011, 03:37 AM | #25 |
subscribed
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
