Old 08-20-2021, 07:00 AM   #1
68ls1
68ls1's Avatar
Hatch repair, where do I get these parts
Have started repair of hatch, was inoperable and couldn't be shut. Pics in my build thread.
After pulling it apart found some issues and need to source some parts.
There is a handle reinforcement which I cannot seem to find online, and the clips (is in first pic) that hold rods. Any leads to where I can get these items, thanks
68ls1 is offline   Reply With Quote
Old 08-20-2021, 07:47 AM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Hatch repair, where do I get these parts
See here: https://www.motorcityk5.com/c-664-69...ody-hatch.html
Old 08-20-2021, 08:00 AM   #3
68ls1
68ls1's Avatar
Originally Posted by DeadheadNM View Post
I cannot find these 2 items there? I have an order in progress for a few other bits from them.
Appreciate your input, learning as i go
Old 08-20-2021, 08:58 AM   #4
1rippen6
That piece is not reproduced, I may have a good used one I'll sell but will have to look. The rod clips at the handle I can't find either, they have a tab that is straight. Everything online had a 90 tab so I've been using on door rod clips. There's a left and right in the doors you just need to figure out which one works best. Also, some of the tabs are longer than others so that comes into play sometimes.
1rippen6 is offline   Reply With Quote
Old 08-20-2021, 09:04 AM   #5
1rippen6
Looking at you picture again and you location, lol. I would say just repair that one, I've seen them a lot worse.
Old 08-20-2021, 11:00 PM   #6
68ls1
68ls1's Avatar
Question Re: Hatch repair, where do I get these parts
Another question. Can someone tell me the specifications of the screw, No 7 in image. I believe this bolts into the reinforcement piece
Old 08-20-2021, 11:04 PM   #7
1rippen6
It does, I can get a picture tomorrow, if no one else can help sooner.
Old 08-20-2021, 11:27 PM   #8
68ls1
68ls1's Avatar
thanks, do you know thread, length & head detail of that screw. I am away from parts and in lockdown here
Old 08-20-2021, 11:31 PM   #9
Tmend
Tmend's Avatar
A photo sent to me by the Blazer Master . #10-24 screw
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 08-20-2021, 11:36 PM   #10
1rippen6
There you go, lol
Old 08-21-2021, 01:35 AM   #11
68ls1
68ls1's Avatar
Attachment 2124199
Thanks, can you please confirm length. Is head an allen key or phillips head?
Old 08-21-2021, 09:14 AM   #12
1rippen6
Here you go
Old 08-21-2021, 01:50 PM   #13
68ls1
68ls1's Avatar
Here you go
Thanks again
Old 08-22-2021, 07:53 AM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Sorry, I meant to share the info that those parts the business lists are available. He does show the clips but I’m unsure if those are offered by themselves. The owner is a good guy.
The metal reinforcement is probably not reproduced but perhaps the vendor has something similar as he is offering a reproduced hatch that presumably has a similar reinforcement.
Old 08-22-2021, 06:50 PM   #15
68ls1
68ls1's Avatar
I did send him an email, and message via FB page, yet to hear back, as I was thinking/hoping the same. I have an order with them for other pieces that I placed last week, but no shipping notification so if they do have them hoping can be added. I will try and call them tomorrow but with time difference it is a little tricky.
The clips they show look identical to ones that were used on our 60 & 70's locally built GM Holdens, so I have ordered some from local supplier, and will see how they go.
Appreciate your assistance
As was mentioned earlier, if I have no luck I'll have it repaired or a new one made.
Old 08-23-2021, 04:50 PM   #16
1rippen6
Here is what the original clips look like.
Old 08-23-2021, 04:52 PM   #17
1rippen6
Here are the ones out of the doors
Old 08-24-2021, 05:40 PM   #18
pound41
The original ones are the same as Carburetor clip that hold the metal accelerator rod/linkage to the Carb. Might have better luck searching that
pound41 is offline   Reply With Quote
Old 08-24-2021, 05:47 PM   #19
1rippen6
I've tried, there is no straight ones to be found, they all have the 90 degree tab.
Old 08-25-2021, 01:07 AM   #20
68ls1
68ls1's Avatar
I searched for Carb rod linkage clip and could only find 90 degree tab, thanks for the possible lead
Old 08-25-2021, 01:10 AM   #21
68ls1
68ls1's Avatar
I spoke with Motor City K5 on Monday, he does make them for his repro hatch, but wasn't selling as an individual piece. I had one made here, will give it a coat of paint before installing
Old 10-15-2021, 02:10 AM   #22
68ls1
68ls1's Avatar
Part 2.
I am looking for the rubber gasket that mounts under the hatch handle and the rubbers that are on the hatch rods.
What are the rubbers on the rods called and what do they do?
Old 10-15-2021, 06:54 AM   #23
DeadheadNM
Carpe manana
DeadheadNM's Avatar
You’ll have to make your own gasket using the old one as a template.
That rubber item looks like a plug used to secure insulation to the firewall. The loose rods I’ve had made use of a foam rubber block like those for the tailgate rods as an anti-rattle precaution I suspect.
Old 10-15-2021, 06:50 PM   #24
68ls1
68ls1's Avatar
Pete are they the same as the ones on tailgate rods, circled here?
Old 10-16-2021, 09:02 AM   #25
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Those will work. What I seem to recall is those for a hatch being slightly smaller than those for a tailgate. If that’s the case, those listed by LMC should be easily trimmed down.
