Old 05-08-2021, 07:56 PM   #1751
Gregski
Gregski's Avatar
Re: A '54 named Busty
forgot to compensate for the circumference of the earth, so she got a little trim
Gregski is offline   Reply With Quote
Old 05-08-2021, 07:59 PM   #1752
Gregski
Gregski's Avatar
these speed nuts are still the bestest way to mount it as the holes are all podawhumpuse, especially when she flexes in the corners on the race track, ha ha
Old 05-08-2021, 08:01 PM   #1753
Gregski
Gregski's Avatar
the wife left the fan outside so I had to hide in my time out corner to primer it, otherwise it was wayyyyy toooo windy AGAIN
FYI the sheet metal I got was galvanized (that's all Home Depot had) so I washed it in Phosphoric acid, then neutralized it with Baking Soda water, then sanded it off, then etched it with Phosphoric acid again, and washed it off with Baking Soda water for the second time.
Old 05-09-2021, 07:49 AM   #1754
8man
That turned out nice.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 05-09-2021, 10:40 AM   #1755
dsraven
Turned out nice.
If you dont wanna see the ends of the rivets you could use steel stud screws, with the big flat head, and speed nuts on the backside. Nobody is gonna look in the glove box though and rivets are not sharp on the backside.
Old 05-09-2021, 10:45 AM   #1756
Gregski
Gregski's Avatar
Originally Posted by dsraven View Post
Turned out nice.
Thanks, I am constantly balancing between Make It Nice and Just Git 'er Done! know what I mean, but I do appreciate the advice.
I already have Pontiac Mike my buddy breathing down my neck saying rivet from the inside out to make it look mo bettah on the inside, (but that's hard and I don't know if that cheap rivet plier gun vice grip thing will even fit) so once it is painted I will make a Game Time decision
Omaha, Omaha, ha ha
Old 05-10-2021, 12:44 PM   #1757
NeoJuice
Nice work
NeoJuice is offline   Reply With Quote
Old 05-10-2021, 01:32 PM   #1758
texxxan
texxxan's Avatar
I've been told that there are three types of people:
1. Those that watch things happen.
2. Those that make things happen.
3. Those that ask what the hell just happened.
You, sir, are those that make things happen. I love the wiring and the glove box. Awesome work.
texxxan is offline   Reply With Quote
Old 05-10-2021, 07:08 PM   #1759
Gregski
Gregski's Avatar
thank you I appreciate that, I try to put in B+ effort 100% of the time, lol
Old 05-10-2021, 10:46 PM   #1760
Gregski
Gregski's Avatar
Man I ain't gonna lie today was one of them days
I spent the first 4 hours just spinning my wheels in the garage, then my soldering iron gave up the ghost, I guess doing all that re wiring wore her out, funny thing is this was my second iron, the first one lasted me 20 years and was the serviceable kind but like an idiot I tossed it and bought this one which barely made it two years and instead of having three tiny screws to open her up they popped in a rivette, oh well I already bought my third
in hind sight I should have gone to a Thrift Store and bought an old fashion one for like .99 cents and had it for another 20 years, I may still do that, Oh Well(er)
Old 05-10-2021, 10:54 PM   #1761
Gregski
Gregski's Avatar
who says I ain't tryin'
here I decided to wash the worst of the three buckets, yes I own three seats just like this one, this one was the dirtiest of them all so I finger if I can clean this one than maybe I can clean the others
plus I need something to sit on while the other two go to the leather house and who knows when I'll get them back
here I am using the orange stuff with plum juice
Old 05-10-2021, 10:59 PM   #1762
Gregski
Gregski's Avatar
so I went to start her today for the first time since looming the entire engine wiring harness and buttoning her up for the last(ish) time
and she would crank but not start
my heart sank, miles of wires hidden in yards of conduit ran through my mind, I dreaded the idea of having to troubleshoot all of that
then I calmed myself down and said: When dealing with LSes You know it comes down to three things right?
1. grounds
2. Grounds
3. GROUNDS
so I eyeballed the ground boundle, and I wiggled it with my hand, yup, nice and tight, started to pull up on them one by one, and the last one ended up in my hand
yup Professor Silky Smooth hide the wiring loom under the engine forgot to ground the separate trick PCM branch, no worries it was only 19 ground wires bundled into one, ha ha
so grounded those, and she winked at me and fired right up
We'll call that the Anti Theft Device.
Old 05-11-2021, 08:44 AM   #1763
8man
I like my Weller, and she fired up. Forget about the stuff before that, she fired up!!! Oh that'll be the day...
8man-aka Robert
Old 05-11-2021, 01:26 PM   #1764
6DoF
6DoF's Avatar
6DoF is offline   Reply With Quote
Old 05-11-2021, 05:02 PM   #1765
Gregski
Gregski's Avatar
put the Grant wheel back on today and made sure everything worked, it's a simple setup with only a turn signal cam and a horn
apparently the kit I had for it only covered all GM cars from 1812 till present but not the 58-62 Impala so I had to buy a different one
nothing like grinding your new paint off the steering wheel to make it go Beep Beep!
Old 05-11-2021, 05:04 PM   #1766
8man
But it's no visible and won't rust, I mean it never rains in southern California...
8man-aka Robert
Old 05-11-2021, 05:05 PM   #1767
Gregski
Gregski's Avatar
First Fill Up! Well 10 gallons just to see if the fuel gauge works, it was reading Empty before.
Old 05-11-2021, 06:26 PM   #1768
NorCalGal
NorCalGal's Avatar
You’re going to scare the hell out of the non-Californians showing what we pay for fuel here.
Jan's 53
NorCalGal is offline   Reply With Quote
Old 05-11-2021, 07:00 PM   #1769
Gregski
Gregski's Avatar
thanks, ha ha, that's exactly why I did it, by the way what ever happened to the concept of quantity discount, we should be paying the least in the Union.
Old 05-12-2021, 06:45 AM   #1770
6DoF
6DoF's Avatar
gas prices or not ... if someone ever convinced me and paid me enough to move to CA, (not actually possible) i'd be driving something pre-73 with a blower out the hood and a bumper stick "suck my exhaust"
Old 05-12-2021, 09:50 AM   #1771
lv2tri2
Smile Re: A '54 named Busty
No more here is fine.
lv2tri2 is offline   Reply With Quote
Old 05-12-2021, 11:01 AM   #1772
Gregski
Gregski's Avatar
Well Forumners dare I say everything electronic works:
1. Headlights (both high and low beam)
2. Parking Lights (as front turn signals I put orange bulbs in 'em)
3. Tail Lights
4. Brake Lights
5. Reverse Lights
6. Brake Lights (as rear turn signals)
7. Dome Light
8. Gauge Lights
9. Horn (yeah I know, this may be like the first truck with a horn I ever owned) and yes it's got it's own relay
10. TCC aka the Torque Converter Clutch (this one was tricky because our trucks have an old style brake light switch so I used a reverse wired relay) and no I did not follow this guys video, lol
How to wire TCC for PCM, ECM, ECU with break light positive. (RELAY) though using all red wire probably does save you some money, ha ha
I am so happy, and I am so grateful for all you guys and gals for following along and encouraging me when I got down.
Old 05-12-2021, 11:10 AM   #1773
Gregski
Gregski's Avatar
but but we got all them Tent Cities to accommodate everybody!
Old 05-12-2021, 11:44 AM   #1774
Tempest67
Tempest67's Avatar
well done, that was a lot of wires to sort through, and you were successful. congratulations.
the truck look great there sitting at the pumps, looks mean without the hood.
Tempest67 is offline   Reply With Quote
Old 05-12-2021, 11:57 AM   #1775
8man
Well darn, what are you going to do now? You need another project....
8man-aka Robert
