05-28-2007, 02:16 AM | #1 |
WTB CPP coil overs 60-72COK
Wanted to Buy CPP coil over shocks and brakets part number 60-72COK Thanks Rob
I guess you could say I知 not really lazy I知 just real good at doing nothing!!!! Last edited by bigblockorange; 06-03-2007 at 10:51 PM. Reason: Change to WTB |
05-28-2007, 10:24 AM | #2 |
Re: CPP coil overs
Nope, but here's a bump for ya.
72 C10 lwb fleetside -stock 350/350 combo |
05-28-2007, 12:45 PM | #3 |
Led Sled! Discs R 4 ME!
Re: CPP coil overs
Perhaps you will get your answers in the suspension fourm. bump
05-29-2007, 11:30 AM | #4 |
Re: CPP coil overs
Bump, Bump
'69 short step with dreams of being a hot rod You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. |
05-29-2007, 01:23 PM | #5 |
Insert Title Here
Re: CPP coil overs
as far as I know they stopped selling them a couple years ago... did they start selling them again?
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 05-29-2007 at 01:23 PM. |
05-30-2007, 01:52 AM | #6 |
Re: CPP coil overs
1loc10 hey I called them today and they do not/do not have them anymore sorry to say.
I guess you could say I知 not really lazy I知 just real good at doing nothing!!!! |
05-31-2007, 12:16 AM | #7 |
Re: CPP coil overs
I'm looking to buy a set, if anyone has a set for sale!
06-04-2007, 10:26 PM | #8 |
Re: CPP coil overs
No Limit Engineering sells a rear coil over conversion kit for 63 - 72 trucks. I could not find it on their website or catalog, but I did get confirmation today that they do sell the kit. The website does have an instruction sheet for installation (that's why I checked to see if they sold the kit). The kit sells for $569.00 and is part #RCC-6372.
I have never bought anything from them, so no opinion about anything. www.nolimit.net
06-05-2007, 08:46 AM | #9 |
Re: CPP coil overs
Cool thanks 69c10step I'll have to check them out thanks Rob
06-09-2007, 01:03 AM | #10 |
Re: CPP coil overs
Just sold a brand new set a few weeks ago at a swap meet in Houston. Never installed. Sold the kit for 250.00
06-09-2007, 11:52 AM | #11 |
Re: CPP coil overs
If you see another set let me know thanks Rob
07-31-2007, 11:16 AM | #12 |
Re: CPP coil overs
Still looking for the coil overs!
07-31-2007, 11:41 AM | #13 |
Insert Title Here
Re: CPP coil overs
just buy coil overs and use cpp's pics a s a guide to make the brackets
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
07-31-2007, 02:34 PM | #14 |
Insert Title Here
Re: CPP coil overs
the shockwave brackets should be able to adapt to coilover
01-24-2008, 04:31 AM | #15 |
Re: CPP coil overs
Still looking
01-24-2008, 04:58 AM | #16 |
Re: CPP coil overs
No limit is a good company, I bought some parts off them a few years ago, top quality!
they do have the kit.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
01-25-2008, 05:57 AM | #17 |
Re: CPP coil overs
I have the CPP kit (Brand new) they stopped selling them because of the low volume of purchases. I will be putting it on my 69 Suburban, I hear that it handles alot better with the coil over kit vs coil springs.
John 69 Suburban 350 V8, 400 Trans, Lowered, 4w Disc Brakes, 55 belair dash 87 & 88 Conquest TSi 2004 Jeep Liberty Renegrade |
01-25-2008, 06:17 AM | #18 |
Insert Title Here
Re: CPP coil overs
what was wrong with my idea
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 01-25-2008 at 06:17 AM. |
01-25-2008, 09:08 AM | #19 |
Re: CPP coil overs
Your suggestion is good, just not for a guy that doesn't have a welder..... The kit the OP was inquiring about is a 'bolt-on'.
01-25-2008, 11:11 PM | #20 |
Re: CPP coil overs
If your going to weld or have welding done, a setup like this will give you the most adjustability.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
01-26-2008, 12:14 AM | #21 |
Re: CPP coil overs
The QA1 setup looks sweet. Is coilovers a worth while investment for a stock height truck? I have swapped in coil overs on a car before and the difference was significant. BTW, 71Dragtruck, your sig made me laugh so hard. I like the hot check with an STD thing....so true.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
01-26-2008, 09:25 AM | #22 |
Re: CPP coil overs
Do you have to covert to a 4link to use this type of setup, The CPP set up has custom bolt-on brackets that mount to the aft end of the trailing arms and to the outside of the frame. I believe your truck will have more stability if the coil overs are mounted outside the frame. Here is a picture.
Drag cars have narrowed frames, wide tires and most of time a 4-link setup, No way or need to mount the coil overs to the outside of the frame.
01-26-2008, 09:32 AM | #23 |
Re: CPP coil overs
No you don't need a 4-link to run the QA1 setup.
01-30-2008, 02:19 PM | #24 |
Daily Driver
Re: CPP coil overs
just bought the competition engineering coilover kit. recieved it today from summit.that and a c-notch. cant wait to get some more weight transfer outta my turd.heard good things about staying with the trailing arms, but would like to go to an aftermarket one if anybody knows of a good product? also trailing arm mount/crossmember
nitrous...the equal opportunity destroyer. |
02-02-2008, 02:48 PM | #25 |
Re: CPP coil overs
Hey BBO
Here are the pictures, I also sent you a PM
