Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 05-31-2011, 02:31 PM   #1
67chevemall
Where to?
67chevemall's Avatar
best way to fill the trim holes??
Hey guys what is the best way to fill in the 30 or so trim holes?
Buddy says weld pennys behind and fill the hole in with the weld and grin smooth? Sounds crazy?
HELP!!
1967 Chevy C/10 V8, 3spd, fleetside lwb.
1967 Chev C/10 step, 383, M21. SOLD
2013 YZ250
2018 GMC Sierra 8' box
67chevemall is offline   Reply With Quote
Old 05-31-2011, 03:14 PM   #2
steverino66
Re: best way to fill the trim holes??
It takes some practice but you can fill the holes with weld from the outside provided they aren't too big (I've never tried one more than about 3/8") - just start on one edge and push the weld across. Grind - carefully - after it cools a little. 80-grit flap disk works great.
I've found the welding works much better for me in quick, short bursts using solid wire and argon/CO2 gas
steverino66 is offline   Reply With Quote
Old 05-31-2011, 04:02 PM   #3
67chevemall
Where to?
All I have is wire with 120V welder. Should I cut little pieces of metal?
2013 YZ250
Old 05-31-2011, 04:36 PM   #4
steverino66
My Lincoln's 120v and I use .023 solid wire; is yours fluxcore (shielded) wire only - can you add gas?
I've read on here guys have welded very thin sheetmetal with shielded, heavier gauge wire, like .030-.035, but for me it was very messy, tends to make bigger holes - that seems more useful for heavier-gauge structural stuff.
You could also try holding or clamping copper/aluminum backing behind the holds
Old 05-31-2011, 07:18 PM   #5
BlueJeep
BlueJeep's Avatar
I've recently been having good luck with cutting little pieces of metal, the philosophy being less weld will have less heat and less warping. Takes some time, but not too bad.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 05-31-2011, 07:38 PM   #6
blacklistcustoms
blacklistcustoms's Avatar
If you back up the holes with some copper plate you can puddle a weld over the hole then smooth off the bump either a flappy wheel or rolloc, my choice is a cutoff wheel slowly and carefully. Its much more controllable and easier to see exactly where you are in the process. just dont bind the disc or put much pressure sideways. This process has served me well in years past.
66 c-10 swb stepside -my daily driver
74 1Ton CrewCab Shortbed 4X4
(2) 91 2500 suburban 4X4
91 K5 Blazer 4X4-wifes daily driver
73 K5 Blazer 4x4- project soon to be 2wd
50 3 window 3100
blacklistcustoms is offline   Reply With Quote
Old 05-31-2011, 09:56 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
If there is access to the back side of the hole, you can permanently close the holes with JB Weld. Iíve been doing it since the 1970ís and never had a failure. Hereís a thread on how I do it:
http://67-72chevytrucks.com/vboard/s...d.php?t=369713
Old 06-01-2011, 12:51 AM   #8
Sillyoldman
#16876
Sillyoldman's Avatar
If you hold a penny behind the hole make sure there is no way for the wire to get past it. I had a hot piece of wire burn through my glove and go into the end of my finger 3/4". That was a good time.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 06-01-2011, 10:28 AM   #9
blazer2007
I read on here about using a steel nail ,weld the head in and grind the rest off
blazer2007 is online now   Reply With Quote
Old 06-01-2011, 10:43 AM   #10
pat 70/71
pat 70/71's Avatar
I have done this just make sure you use common nails and not sinkers(coated nails) .It worked great for me ! not too much heat and when tacked simply cut the shaft of the nail and you are good to go! cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 07-23-2011, 09:38 PM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
if one uses the search features of these forums, we can find numerous threads on this topic.
That's how I found this thread, marks jbweld thread, and many others.
I like marks jbweld suggestion, but I think my favorite suggestion is to use a nail head and weld it in, then grind it down.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-24-2011, 12:13 PM   #12
stich626
man, v bulletin search function, is for the birds.
I like the nail head idea..
the jb weld sounds good,
stich626 is offline   Reply With Quote
Old 07-25-2011, 09:39 AM   #13
67chevemall
Where to?
Wow the nail head idea is great!
2013 YZ250
Old 07-29-2011, 04:46 PM   #14
Jonboy
Slots go on anything!
The easiest way to fill the holes is to use panel bond to fill them. You can use a penny as a backer inside the panel. Works pretty slick this way, and goes a heck of a lot faster, too. Panel bond also works well for filling cab seams and such, too.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 07-29-2011, 07:09 PM   #15
Rdrdave
Broke and still trying
Rdrdave's Avatar
I've done the nail idea. It works and gives you something to hold onto without burning a damn hole through your finger! DON'T ASK!
Rdrdave is offline   Reply With Quote
Old 07-29-2011, 07:25 PM   #16
stich626
do tell
Old 07-30-2011, 12:58 AM   #17
LostMy65
LostMy65's Avatar
I use the embedded google search this site provides at the top of the forum page.
http://www.google.com/custom?domains...D%3A1%3B&hl=en
Old 07-30-2011, 08:05 AM   #18
stich626
I'll have to try that
Old 09-16-2021, 06:33 PM   #19
bob arrington
Junior Member
really excellent, saved in my favorites, many thanks, bob
bob arrington is offline   Reply With Quote
Old 09-18-2021, 12:13 PM   #20
67swb72klb
67swb72klb's Avatar
The JB weld will give you ghost lines down the road...
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 09-18-2021, 02:08 PM   #21
Getter-Done
Getter-Done's Avatar
Make or buy a copper backing plate.
2 examples in the links below.
Link for copper welding backer: https://www.eastwood.com/4-in-magnet...ng-backer.html
Link for copper spoon:https://www.walmart.com/ip/Welding-C...4a5a787d0b1f4b
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 09-19-2021, 06:11 AM   #22
4u2nv
From shrinkage ????
4u2nv is offline   Reply With Quote
Old 09-19-2021, 09:11 AM   #23
67swb72klb
67swb72klb's Avatar
Filler does not like to stick to it and due to the metals expanding and contracting is what I think happens.
Old 09-19-2021, 04:51 PM   #24
bob arrington
Junior Member
not to worried bout ghost lines...lol
Old 09-21-2021, 09:06 PM   #25
LostMy65
LostMy65's Avatar
I found the best way to fill the holes is by using the stock trim.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
