04-17-2018, 05:10 PM | #1 |
Cast Headers
will the headers from a 67-72 small block fit our 60-66 sbc with manual transmission. I have been looking in wrecking yards and for sale sites for stock cast headers for some time and finally found a set of newer style yesterday but want to make sure they will fit. These are the ones I am talkjng about.
Thanks, taclem |
04-18-2018, 01:12 AM | #2 |
60-66 Nut
Re: Cast Headers
Those exhaust manifolds should work. You'll just have to make sure the exhaust pipe doesn't interfere with the bottom arm of the clutch bellcrank. I'm thinking there should be plenty of room, but just make sure.
04-18-2018, 01:39 AM | #3 |
Re: Cast Headers
Thanks Captain.
06-09-2021, 11:54 AM | #4 |
Moderator
Re: Cast Headers
Old thread but I just found these, maybe you've seen them before?. 1-5/8" primary and 2-1/2" outlet:
https://www.holley.com/products/exha.../parts/8525HKR
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 06-10-2021 at 08:04 AM. |
06-09-2021, 12:29 PM | #5 |
Re: Cast Headers
Circle track guys are found if the 1 ton or above vortec 350 exhaust manifolds.
They look alot like standard manifolds but flow a bit better. Especially with the flange opened up. |
06-09-2021, 09:34 PM | #6 |
But Found Her 25yrs Later!
Re: Cast Headers
2.25 Rams horn also is an option.
06-13-2021, 01:29 AM | #7 |
Re: Cast Headers
06-16-2021, 05:52 PM | #8 | |
Re: Cast Headers
06-16-2021, 07:20 PM | #9 |
Re: Cast Headers
I've got the cast iron tru-rams on mine and I've got no complaints.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
06-16-2021, 07:30 PM | #10 |
Re: Cast Headers
^^^ Bravo, Looks great!^^^ nothing against the LS guys but I love a sweet old school small block.
06-16-2021, 10:55 PM | #11 |
Re: Cast Headers
I have the same ones on my sbc motivated 64.
