04-28-2021, 02:43 PM | #1 |
Remove baffle on new valve cover?
Going with these Holley valve covers (241-292) as the ones that came with the HT383 had no provision for a breather, 15/16” hole, for PCV on both sides.
Anyway there is a baffle fairly close to the opening for the PCV but on the other side, breather side and oil fill, is it okay to remove the baffle? Wouldn’t be able to get funnel in very far and oil would drain in very slowly? Thanks for any help. Posted via Mobile Device |
04-28-2021, 03:17 PM | #2 |
Re: Remove baffle on new valve cover?
in my experience if you remove the baffle oil will be pulled into the pcv valve and it'll smoke like a freight train.
04-28-2021, 03:29 PM | #3 |
Gonna leave it in on the PCV side, I want to know if I can remove it on the Breather/Oil fill side?
04-28-2021, 03:36 PM | #4 |
I would leave it as is. There is a lot of oil splash that will wind up soaking your breather etc. They put it there for a reason so I would leave it alone.
I guess you could try it but if you are like me having to pull stuff apart twice bugs me lol! Last edited by MySons68C20; 04-28-2021 at 03:37 PM. Reason: spelling |
04-28-2021, 09:01 PM | #5 |
I had to think about it a few minutes but I think I would leave it. If that's where the breather is going to go then definitely leave it in . It will be a small pain to put oil in it but at least the breather will stay nice and dry.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
04-28-2021, 10:02 PM | #6 |
60-66 Nut
IMO you should be good to remove the baffle. For one a new engine should not have any blowby and secondly since it is the breather, there should be a small amount of air coming in thru the breather. Additionally the little 'walls' cast into the cover will help deflect oil splash from the rocker arms away from the breather. There's my .02.
04-29-2021, 09:03 AM | #7 |
If the only use for that hole will be as an oil fill hole and it will have a solid oil fill cap/plug when not adding oil, then remove the baffle.
If is is going to be a dual use air breather - oil fill hole, then keep the baffle. The reason the OEM air breather filter is in the air cleaner is under some operating conditions, there is enough blowby that air comes out of the breather. With the OEM setup, that air gets sucked back into the motor and burned. Without the baffle, you could wind up with a lot of oil on the top of your nice valve cover. |
04-29-2021, 09:22 AM | #8 | |
I get that there is POSITIVE crankcase pressure that is being vented and regulated with the PCV, but why doesn't having basically an open, filtered port, the breather, destroy the point of the PCV valve. Isn't there the same pressure under each valve cover? |
04-29-2021, 11:13 AM | #9 | |
04-29-2021, 12:15 PM | #10 | |
04-29-2021, 12:17 PM | #11 |
04-29-2021, 08:02 PM | #12 |
The PCV doesn't do anything at wide open throttle because there is no engine vacuum WOT. But there is a vacuum over the top of the carburetor at full throttle. So at WOT and high crankcase pressure, the vent side is under a vacuum in the OEM plumbed setup.
05-02-2021, 10:56 PM | #13 |
Use spacers to give it a bit more gap for the oil flow. Use washers if need be, but make sure those don't back off with some thread locker. You'll need longer fasteners most likely. EDIT: maybe just space out the end with the lone fastener... as that looks like an intentional gap and making it bigger isn't likely to cause interference with your rockers. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
05-20-2021, 09:09 PM | #14 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
