12-10-2015, 02:27 PM | #1 |
Need advice, on my "Surprise!"
Lately, I’ve been feeling like I should be calling this truck Gomer Pile, “Surprise, Surprise, Surprise” lol
Yesterday, I was trying to follow the orange wire from the fuel pump relay, and found the frame is cracked around the rear passenger side shock mount. I was only trying to find stray wires around the tank. The damn thing quit on me the other night, right across from the part store. Bought a new fuel pump relay, installed and still nothing so I called someone and they told me to run a wire from the orange wire on the relay connector to the battery and it started right up, but I have to turn the ignition switch hard. And not to mention it is killing my new battery, I’ve had to charge it twice already. Any idea what this could be or where I could chase this wire down to see what’s going on? Because it is not getting power on its own. 1990 suburban 1500 350 tbi/700 r4 As always thanks in advance for all advice.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
12-10-2015, 03:07 PM | #3 |
Re: Need advice, on my "Surprise!"
I'm no guru, but I imagine a hammer and a welder are in your future. Maybe adding additional bracing, for good measure?
Current Projects: 1984 GMC, LWB Fleetside, 305/350 - Currently Doing TBI Conversion 1966 GMC, SWB Stepside, 350/200-4R - Currently waiting patiently. |
12-10-2015, 03:41 PM | #4 |
Moderator
That's been airborne more than once.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
12-10-2015, 04:45 PM | #5 |
Unless the shocks are just too long or the bump stops are gone.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
12-10-2015, 08:12 PM | #6 |
I would get that fixed asap.... I hope you can weld, or know someone that can.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
12-10-2015, 08:35 PM | #7 |
12-10-2015, 08:50 PM | #8 |
That's one serious crack, straighten, weld, and reinforce that asap!
12-11-2015, 08:00 AM | #9 |
I have never seen that type of damage on a square . That is unusual . You may have a shock that is seizing up or frozen and putting undo stress on the frame . I would not drive it any until you get that repaired and some new shocks .
12-17-2015, 06:44 PM | #10 |
Scared the ish out of me when I saw that. Trying to get a welder out to look at it is an uphill battle. Roughly how much could this end up costing? Thanks guys.
12-17-2015, 07:18 PM | #11 |
I know the pieces fit
I'm no welder but I see a lot more prep there than actual welding. Those are gas lines under the split, aren't they?
12-17-2015, 08:55 PM | #12 |
Moderator
Fuel, Vapor, Fuel-Return, and Brake lines probably. Those will need to be removed along with the shock and the frame bent back to some approximation of its' original shape.
12-18-2015, 08:35 AM | #13 |
I think there is enough distance between the lines and the crack you could get by with wrapping them with a heat shield to protect them . Just loosen the straps and pull them away from the frame some and wrap it . I think at the very least you will have to remove the bed to have proper access .
It looks like the part the shock is attached to is bent up and will need to be bent back down and welded . Best I can tell it looks like the lower part of the frame is not bent , just the shock mount pushed up . If the bed still looks like it lines up than this is most likely the case . To get a proper weld all the crack areas all the way around will have to be ground down to create a fill weld to penetrate enough to make a permanent fix . Do not let anyone do a surface weld . It will not hold and you will be doing it again at some point . Hope things work out . |
12-18-2015, 10:32 AM | #14 |
Moderator
Fiberglass covering Kaowool ceramic fiber refractory blanket wrapped around the lines would keep em safe. I'd go at least a foot in both directions from the weld area.
It's a Suburban. That's going to be nasty if the body tub has to be lifted off to bend it back...
12-18-2015, 11:49 AM | #15 |
I forgot about it being a Burb . Yea , that would be a task . It is possible to fix from the bottom if on a lift with the proper tools . Will not be able to weld the top so care would have to be taken care of for the weld to penetrate all the way to the other side . A good welder knows how to do it .
Not an impossible task , just a tedious one with the right equipment . |
12-20-2015, 11:06 AM | #16 |
If you can't find somebody to weld it local, get outside the city and look for a regular repair shop (aka service garage) in the middle of farming country. Many are accustomed to doing fixes like this and it won't make them blink twice.
Frozen shock possibility aside, this is also an extreme example of why not to run heavy duty shocks. I used to get my shock mounts pounded out all the time until I went back to regular shocks. Alex. |
02-03-2016, 06:34 PM | #17 |
Don't know how to post photo from one thread to another...I started a new post in search of a welder
02-03-2016, 07:03 PM | #18 |
I'm all for learning to do it yourself. Do you know somebody that can weld that will help you and make sure it's done right if you buy a welder and all the gear? If the answer is no, I believe you could get it fixed by a pro for cheaper than you could buy all that stuff. Then buy the welder and gear later, and learn on something less important than your frame.
07-07-2016, 01:33 AM | #19 |
Finally found a frame and bodyshop, emailed photos and he said I'm looking at $500-$600 is that a fair price and what gage metal should I request to reinforce that area? Thanks.
07-07-2016, 08:53 AM | #20 |
I would have guessed around $500. Since it is a 'burb rather than a truck with the box removed, everything will take twice as long. I could see a job like that taking me all day. A good shop with all the right tools would probably be half a day. Most places charge more than $50 nowadays so I could see shops charging $100/hr x 5 = $500.
