Old 04-14-2014, 04:33 AM   #1
GMC70c20
mustang II stering shaft options
I have a c10 with a mustang II front axle from fat man. I am just about to set the cab back on the frame but am unsure of what to do for a steering shaft. The engine is set back 4in and is a ls with 1-7/8 headers so I may have a odd ball application. What are you guys using for a steering shaft? if you had pictures that would be great.
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 04-14-2014, 08:56 PM   #2
CHRIS67GMC
CHRIS67GMC's Avatar
Re: mustang II stering shaft options
Your steering column will effect this. Figure out your splines on each end and run 3/4 inch dd shaft. You should be able to connect the 2 points together. If you do not have a straight path then a carrier bearing and more joints required.
Get parts from Flaming River or Borgison or contact a member to order them from.
CHRIS67GMC is offline   Reply With Quote
