11-17-2015, 12:13 AM | #1 |
What drive shaft to use
Just totaled my 04 cts V and thinking of buying it back and installing the LS6 and T56 in my 70 suburban. Also may add the 2010 Cts v blower I have on top of it.
My question is what driveshaft are you guys using the stock one and just changing the length of it. I have the the driveshaft from my Cts v so was thinking of bringing it to a local driveline shop and having the front yolk adapted onto the stock driveshaft. I wonder how much my stock driveshaft can handle?? |
11-17-2015, 03:56 PM | #2 | |
Re: What drive shaft to use
11-18-2015, 10:13 PM | #3 |
Buy a new shaft.
How are you going to put a blower designed for rectangle ports on a cathedral port head?
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
11-18-2015, 11:58 PM | #4 |
11-19-2015, 10:10 AM | #5 |
Check out the Drive Shaft Shop
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-19-2015, 04:57 PM | #6 | |
http://www.ebay.com/itm/LS1-Cathedra...lWTi0i&vxp=mtr |
04-08-2016, 10:26 PM | #7 |
So I ended up building a 6.0 with CTS V LSA blower and heads with brian tooley stage 3 camshaft. I will problbly be making anywhere from 600 to 625 HP. I plan on starting the swap in the next month. So the stock driveshaft will probably grenade or snap in half correct?
So far I have a Th400 built for boost with a Sunex forged yolk. I may install a gear vendors overdrive unit on the back of the transmission. From what I understand I should keep it a 2 piece driveshaft with a carrier bearing Correct? I believe a one piece shaft will have a vibration. |
04-08-2016, 11:16 PM | #8 |
I put a 1 piece in my suburban with a GV unit and even with my pinion angles correct I still have a vibiration. I will be going back to a 2 piece to try and resolve the vibiration
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
