Old 05-04-2021, 12:38 AM   #1
Asshat
Asshat's Avatar
Water pump heater hose size? Straight six 292
The formed water pump return hose is 1” ID; and it seems to me the heater hose outlet is 7/8”. The one from the thermostat is 5/8”.
I don’t think there is 7/8” heater hose, is there?
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 05-04-2021, 07:40 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Water pump heater hose size? Straight six 292
Gates makes a 7/8" heater hose but I thought the heater hoses were 3/4" and 5/8".
Old 05-04-2021, 10:44 AM   #3
Asshat
Asshat's Avatar
I thought so too. The water pump outlet for the heater is not 5/8” or 1” Is.
292, 4-speed
Old 05-04-2021, 11:05 AM   #4
The Rocknrod
Moderator
Oh I think I see what might be the issue. If you look at a National Pipe Thread Reference Chart you'll see that a 3/4" Pipe thread is a tad over 1", they don't go by the normal nut and bolt references most of us are used to.
Old 05-04-2021, 11:31 AM   #5
Asshat
Asshat's Avatar
Not sure what that has to do with National Pipe Thread sizes.
The water pump connections are cast. Just not sure why they chose a size different than the standard heater hose size. Unless it was intended to match the heater core inlet, which is also larger than 5/8”.
Is there a special hose from the factory that went from the water pump to the heater core?
292, 4-speed
Old 05-04-2021, 11:58 AM   #6
The Rocknrod
Moderator
Maybe you can find a dual ID heater hose like this as an example - https://www.amazon.com/Gates-18083-H.../dp/B00LGPIWN0
It's hard to tell what your looking for though, no pics. is it in this pic?
Old 05-04-2021, 05:28 PM   #7
Asshat
Asshat's Avatar
Yes - I it is the 63-64 292 version.
292, 4-speed
Old 05-04-2021, 05:47 PM   #8
Asshat
Asshat's Avatar
Pics...
Thought I had more; I’ll have to post some later this evening.
292, 4-speed
