02-06-2023, 09:34 PM | #151 |
GEARHEAD
Re: HG's Dream Car Build - Shelby Cobra Kit
I put gas in it, turn the key and the pump starts so that's good. Did it several times trying to get gas to the engine. I could here it gurgling up there. No leaks.
So I tried to start it. Nothing. It just cranks but doesn't fire. Not the absolute worst situation. At least it cranks, the fuel pump runs and it's not making weird mechanical crunching noises. I sprayed some brake cleaner in to see if it was a fuel issue and still no firing. I need to let the disappointment simmer down a bit. I've got to check some voltages and pressures next for troubleshooting.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
02-08-2023, 05:46 PM | #152 |
GEARHEAD
Did a bunch more testing, didn't find my problem, so I called ford performance. The guy got to the most likely issue in seconds and said to check the pulse ring and crank trigger sensor. I thank him and start fiddling, then look in the box of coyote motor parts and see this...
02-08-2023, 05:48 PM | #153 |
GEARHEAD
Hi, my name is HG and I am a moron. I'm not always a moron, but there are times it can not be denied. For my next trick I'll be pulling the transmission, clutch and flywheel out to put that little ring on the crank.
02-08-2023, 09:42 PM | #154 |
GEARHEAD
Got the transmission out. Will finish disassembly tomorrow or Friday.
02-09-2023, 10:54 AM | #155 |
LOL!!!! Don't worry, we all do stuff like that at some point . At least it wasn't that difficult to repair.
02-09-2023, 05:54 PM | #156 |
That sucks, HG. At least the odds are now in your favor of making rumbles and roars soon.
'71 C/20 350/T350. |
02-09-2023, 06:17 PM | #157 |
Dang HG.. I feel your pain about the no crank issue..I'm fighting one myself at the moment...
I'm replacing my crank sensor to see if it solves my problem... I tested my old one going by a how to on YouTube..if I did the test correctly ,then its bad.. Not sure how it went bad ..it was a running engine when I did the swap.. I sure hope the cs fixes it..dang thing cost $110 before my buddys business discount..
02-09-2023, 10:31 PM | #158 | |
GEARHEAD
02-09-2023, 10:36 PM | #159 | ||
GEARHEAD
The flywheel is off and there wasn't magically a new forgotten pulse ring on it. At least I didn't lose or scrap the one I had. But I can't find the dang pilot bushing clutch plate holder thingy so I can't reassemble the clutch until tomorrow when I can borrow one from the mechanic in town.
02-10-2023, 01:07 AM | #160 |
It didnt help HG..new sensor...hook scanner up in live..no rpm signal
02-11-2023, 10:37 AM | #161 | |
GEARHEAD
The clutch and flywheel (and pulse ring) are back on. Going out this morning to get the bellhousing and starter back on, then a friend is coming by to help get the tranny back in later today.
02-11-2023, 11:29 AM | #162 |
I back pinned the signal wire from the crank sensor at the ecm...I'm getting a crank pulse signal there..
So the new crank sensor is working..I retested the old sensor and it's working also.. So there was nothing wrong with my original crank sensor.. Gonna put my ecm in a buddys truck and see ir itll crank and run.
02-11-2023, 05:41 PM | #163 | |
GEARHEAD
The cobra is a runner! And a driver! I need to bleed the brakes and adjust the clutch but it starts right up and drove around our driveway with no real issues. Video to follow.
02-11-2023, 05:44 PM | #164 |
The cobra is a runner! ...COOL!!!!
02-11-2023, 09:49 PM | #165 |
GEARHEAD
First start https://youtube.com/shorts/1A0IPjqJHm4?feature=share
First drive https://youtu.be/fuvyT3rAKiY Second drive, took the wife for a cruise https://youtu.be/FafDvftkwvk
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 02-11-2023 at 11:03 PM. |
02-11-2023, 10:24 PM | #166 |
Sweet test drive!!...did you have the heater on high??!!
02-11-2023, 11:11 PM | #167 |
GEARHEAD
Heater?? What's that? It was really nice out. At least 35f, light breeze, sun was shining. I had long sleeves on. I even grilled pork tenderloin for supper. It was a beautiful day!
Spring in MN https://youtube.com/shorts/5z8ZLjSHDok?feature=share
02-12-2023, 11:15 AM | #168 |
Very cool, the go cart stage
02-13-2023, 08:31 PM | #169 |
GEARHEAD
Haven't done much since getting it started and moving under its own power. I broke the clutch in switch somehow so fixed that with a couple zip ties. I have an oil leak from the pass side valve cover, which is odd since it's an o ring gasket and everything is tight. I connected the fan wire from the control pack harness to the car harness wire for the fan but didn't try it out. I'll need to let it run long enough to get to 195f to kick the fan on but I don't have any gauges hooked up yet so that's what I'll be working on next I think.
I'm not going to use the metal dash from the kit, except as a pattern and for holding gauges temporarily. I'm trying to decide on a type of wood that I think will look unique and be formable to work in the car. I kinda like this hackberry sample. Can't really do a burl wood except as a veneer. I'll probably have to make it in at least 3 pieces. IDK, it's still just a jumble of ideas in my head that isn't settling on any one thing yet.
02-13-2023, 08:57 PM | #170 |
Equal opportunity joke ofender
What about using the 3M di noc wood vinyl on the aluminum kit dash? Would give you several different wood look choices.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
02-14-2023, 02:04 PM | #171 |
"Tail Gate Best Seat In House"
What I bought and through the years did ny own thing
I just seen that the tinkering I posted back on the first page of this site is no longer shown as it was through Tiny Pics which is no longer in business ..
So, here it is again with the last photo of my old place when we last lived and since sold , bought the place in 1967 for $ 5800.00 and sold it for $ 250.000 ,,I tinkered all through this transforming on my own ,,just used some help Moved to Idaho in 2012,
When you learn a thing a day you store up smart. Last edited by GOPAPA; 02-14-2023 at 02:18 PM. |
02-14-2023, 04:00 PM | #172 | |
02-14-2023, 10:08 PM | #173 | |||
GEARHEAD
I just realized I started this thread a year ago today. Just under a year to make it go. Not bad really.
02-20-2023, 01:31 AM | #174 |
GEARHEAD
Started working on the dash. I made a cardboard template and after 4 tries I think I have a gauge layout I like. I wanted the tach and speedometer behind the steering wheel. There are 4 other small gauges, only 1 will fit between the tach and speedometer. I tried putting all of them within that circle of the wheel but it just wasn't fitting where you could easily see all of them. So I set up 3 to the right in a way that looks good to me.
Going to try and find a 3 position toggle switch for the blinkers and put it to the left of the column, close to where a column mounted one would be. A guy makes a blinker setup based on an old VW part but over $300 is pretty pricey just to do what a $5 switch can do. I will need to pick spots for the ignition switch, start button (I want one), headlight switch and dimmer, and horn. The wife thinks it should have tunes other than the exhaust notes, so I'm thinking just a Bluetooth setup with Amp driving the speakers. Minimal head unit. The spot in front of the shifter will make a good spot for a speaker. No idea yet where other speakers will go. As far as getting the gauges working, I have the sending units for the engine connected, got confirmation from Dakota digital that the tremec VSS output is good enough for the speedometer, tach wire comes from the engine harness, just leaving the voltage gauge wires which are pretty straight fwd. I think I'll have those connected by next weekend. Lots more looking up wheels and trying to figure out what will fit. I measured what it on the chassis now and measured the width of the body at the top of the wheel opening. Stock wheels are 15x7 with 4.75" bs. I have 2" more room to the inside on the rear. Really no room to the inside in front. Only looking at 8" wide in front, with the same bs, which should fit to the wheel opening really well. Lots of room in back because the body is based on the 427 cobra which has larger tires. Found an online calculator for backspacing/offset and also for comparison of wheels based on those values. https://www.customwheeloffset.com/ti...ogle&utm_term= Looks like I can fit an 11" wheel with the right bs. The hard part is finding a wheel style that has the right sizes for both the front and rear, most don't. I could run a 9" front and rear but that's not the look I want. So I have a couple options, one is great for fit but I kinda like the look of the other more. I've contacted the mfr about getting a rear wheel that they sell with the right offset but wrong bolt pattern (off by .7mm). So many decisions to make.
02-20-2023, 11:33 PM | #175 |
GEARHEAD
Started working with the wood. Need to buy another hole saw. I found a spot for the gauge controller and just used velcro to hold it. Got a little elbow for the radiator overflow. Now I just need to decide on what tank to use.
