Old 07-30-2022, 12:14 PM   #301
layinrocker65
layinrocker65's Avatar
Re: "Sweet Pea" 1975 Cheyenne 20
Just a heads up, DD wants a dedicated ground for the fuel level sender to the control box. It’s shown in the instructions and all 3 DD gauges I have installed required it for accurate gauge reading.
Your going to love those gauges.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 07-30-2022, 03:40 PM   #302
ShortHaul
ShortHaul's Avatar
Copy... I got everything wired up this morning and began the setup process. I've got every gauge working except oil pressure. I'm attempting to read oil pressure through the BIM (aka connected ot the OBD2 port and reading from the PCM) but it's giving me the EE error code. All the other info from the BIM is working fine (Tach, Temp, Speed) Not sure whats up. Im not getting a check engine light... so I assume the engine has sufficient oil pressure.
Just read that some of the early "LS" swap PCMs do not supply oil pressure readings... Great. I wonder if thats what I have.
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 07-31-2022, 12:18 AM   #303
layinrocker65
That’s probably your issue. If your oil pressure sensor is a one wire unit, the ecm doesn’t read it. I had to use the DD sensor in my 74. Just used the port above the oil filter.
‘53 GMC COE stock
Old 07-31-2022, 11:37 AM   #304
ShortHaul
ShortHaul's Avatar
Yep. That was the deal. I had the port cover from ICT billet with the 1/8" npt hole in it. Swapped that puppy on and routed the DD oil pressure sensor... now we're reading on all fronts! Stoked! Had to quit early due to family obligations, but everything is wired up, programmed and set up. Just need to tidy up all the wires and put it all back together. I'm super happy to have working gauges and a tach!
Untitled by awesome_adawson, on Flickr
Old 08-22-2022, 08:46 PM   #305
ShortHaul
ShortHaul's Avatar
I got the gauges all wired in and tucked away, they look fantastic! So stoked on the outcome. I'll take some pics at night too, they look great with the back lighting.
However, on a test drive I found my fans aren't kicking on. Grr... They've worked before. Now they aren't kicking on. Tuner says they're programmed to come on at 196 and 204 (respectively) I did the 5 minute check up (fuses, ground, wiring) and its all kosher. Not sure how to check a relay, but everything looks tidy and right. Im baffled. Any suggestions? I have a show coming up over labor day weekend... if I cant get it figured out by then I'm just going to wire them to a switch.
Old 08-24-2022, 10:13 PM   #306
ShortHaul
ShortHaul's Avatar
I'm no photographer, but here they are...
Old 08-24-2022, 10:19 PM   #307
ShortHaul
ShortHaul's Avatar
I drove her to work today, 40 miles, mostly freeway. This was the first commute since the swap. She drove like a dream! 70-75 at 2300 rpm. Cruised right along. Stayed nice and cool, no weird shakes, noises, problems. From pulling the motor on Jan 1 to commuting to work worry free on 8/24. Quite the process! I'm sure there will be some things I iron out as I go, but its safe to say she's a runner! Thanks for all the help from everyone who has pitched in along the way.
Old 09-01-2022, 11:39 AM   #308
Rich84
Rich84's Avatar
Did you get the fans sorted out?
Rich84 is offline   Reply With Quote
Old 09-07-2022, 10:34 AM   #309
ShortHaul
ShortHaul's Avatar
Not entirely. I’ve got them running on a switch right now, which works fine… but I’d like to have them running as they’re meant to.
Old 11-13-2022, 02:28 PM   #310
ShortHaul
ShortHaul's Avatar
Been away for a bit, but Sweet Pea is running strong as ever. Lots of use as a daily driver, firewood hauler and all around pickem up truck. Ive got some pics from the C10 Intervention show back in Sept, So i'll upload em now.
The lineup!
Old 11-13-2022, 02:32 PM   #311
ShortHaul
ShortHaul's Avatar
And now a few pics of her less fancy daily life
Old 11-13-2022, 08:48 PM   #312
Getter-Done
Getter-Done's Avatar
Nice.
84 Chevy K-20
Old 11-13-2022, 10:43 PM   #313
Joe Pass
Joe Pass's Avatar
Well done.....
Joe Pass is offline   Reply With Quote
Old 11-14-2022, 06:52 AM   #314
Corts60
Just here to tinker
Corts60's Avatar
Beautiful work my friend!
Old 11-14-2022, 06:06 PM   #315
Factory Guy
Factory Guy's Avatar
Looking good as always! Nice to have a 3/4ton, when you want to carry a load!
Factory Guy is offline   Reply With Quote
Old 02-06-2023, 01:50 PM   #316
ShortHaul
ShortHaul's Avatar
I've been dealing with the sticky steering wheel for years, and finally decided I'd had enough. I found this NOS Truckline Sport Grip wheel cover on ebay a while back. Finally got around to installing it. I love it. Such a period correct, old school feel. I swear my dad had one of these on every truck we owned when I was a kid. No more sticky fingers, and it looks pretty dang cool in my opinion. Love the original box and hand drawn instructions.
Old 02-06-2023, 02:46 PM   #317
CG
BlahBlahBlah
Love the steering wheel cover, Ive put a lot of those on over the years. Didn't think there were any out there anymore. Id like a black one, Ill have to have my brother check E bay for me.
Monroe Swap meet May 18-19.
Mike has the same spots for the NW guys he's had forever.
Lunch time BBQ at the spaces.
If you have stuff to sell bring it along.
If you have a question PM stllookn (Mike) here via the board.
https://67-72chevytrucks.com/vboard/...d.php?t=851291
Old 02-14-2023, 01:00 PM   #318
Factory Guy
As far as the sticky steering wheel goes...I have been doing some research and apparently the way to solve it, is you apply some Oxi Clean to the plastic parts and it neutralizes the degradation of the plastics in the steering wheel.
I have NOT done this to mine yet.
Test in a small area to start!
Mine needs it too!
Old 02-16-2023, 12:59 PM   #319
Rich84
Rich84's Avatar
Hmmm.
Funny how some do it and others don't. My '86 is sticky in damp weather but my '84 which has an '85 wheel is never sticky.
Old 03-06-2023, 04:44 PM   #320
rodstored-72
chevy truck fan
rodstored-72's Avatar
i like the steering wheel cover... reminds me of my 'ol '79 big10 which had one when i took over driving duties from my dad. gauge question: did you have any issues with the fuel gauge? if not would you be willing to share how you hooked it up? I am having issues with it reading in mine.
thanks!!
rodstored-72 is offline   Reply With Quote
Old 03-12-2023, 03:07 AM   #321
ShortHaul
ShortHaul's Avatar
thanks!!
Hey sorry for the delayed reply. I’ll have to look back through some pictures, but I’m fairly certain I hooked it up just how the Dakota instructions said to. Set to the proper ohms for the 87+ sending unit.
Old 03-13-2023, 04:27 PM   #322
rodstored-72
chevy truck fan
shorthaul. thanks for the reply, I thought i had it wired according to DD instructions as well, but to no avail... I checked cont. between each ends of the fuel gauge wire from the dash end to the selector switch (dual tanks) it is good there. I guess I am confused on the grounding issue? i have '87 tanks & '87 sending units. the gauge shoots to full at start up
anyways... nice job n the dash
Old 03-13-2023, 10:49 PM   #323
ShortHaul
ShortHaul's Avatar
Yeah I did away with the selector, and wired it all as layinrocker describes in his post above, with a dedicated ground from the sender direct to the DD control box. And just confirming you set the ohms to the proper level? (0-90 if I recall) perhaps try running a single wire from the sender, bypassing the tank switch to see if that’s the culprit.
Old 03-20-2023, 01:13 PM   #324
rodstored-72
chevy truck fan
shorthaul, thanks again for the reply. I think I will start a seperate thread (don't want to hi-jack you) the truck looks cool & looking foward to more updates....
Old 03-23-2023, 10:53 AM   #325
ShortHaul
ShortHaul's Avatar
No worries, thanks and good luck sorting it out. I’m sure you’ll get it dialed in. Don’t be afraid to call Dakota Digital directly.
