Old 08-03-2021, 02:12 PM   #1
Thealien
Thealien's Avatar
I want a picture of
The blower motor connector on an AC vehicle. All the wires pulled out and I am not 100% sure even after looking at the wiring diagrams.
Also not sure I have the correct connector.
The wire colors are blue, brown, yellow and orange.
Trying to get the heat working. None of the vacuum lines hooked up, broken levers on the controller, and wiring issues.
Mark
Old 08-03-2021, 07:03 PM   #2
mr.mud1
mr.mud1's Avatar
Re: I want a picture of
hi,if you need a picture of the connector on the heater fan switch from an air conditioned truck,here's a couple pics from my 72 c20 with a/c.the flash blurred the colors but it's yellow on top,orange then brown on the bottom with a light blue on the inside row of terminals.hope that's a help.Greg
mr.mud1 is offline   Reply With Quote
Old 08-04-2021, 07:52 AM   #3
Thealien
Thealien's Avatar
Could someone tell me the correct wire placement on this connector? I can't quite figure it out by the picture above. Correct my diagram below. This would be looking at the back of the connector.
Old 08-04-2021, 07:58 AM   #4
Thealien
Thealien's Avatar
This is correct.
Old 08-04-2021, 08:46 AM   #5
mr.mud1
mr.mud1's Avatar
Is this correct?
Yellow on top,orange,then brown,blue on the inside as per my picture
Old 08-04-2021, 09:09 AM   #6
Thealien
Thealien's Avatar
Which is as my picture shows, thanks for your help. I just swapped my wires and the blower now works on all 3 speeds.
Now I need to replace the controller, switch, and run new vacuum lines.
Old 08-04-2021, 09:18 AM   #7
mr.mud1
mr.mud1's Avatar
Good news.need any other pics,just holler.Greg
