06-22-2022, 08:11 AM | #26 |
Re: Did the 1/2 ton short beds come with a two piece driveshaft?
Keith that's an awesome offer. I wish I had a list made up already
06-22-2022, 05:50 PM | #27 |
There is at least one more carrier bearing as well, the “Heavy Duty” which is in the triangular shaped clamshell. That’s what is on my ‘69 short step which is 307/TH350 powered and 3.07 gears. Obviously a two piece since it has the carrier bearing.
06-23-2022, 01:13 AM | #28 |
thanks, would you have a pic to share with us please and thank you
06-24-2022, 05:18 AM | #29 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
I dont think the SWB K (4x4) trucks had two piece shafts. Im not sure any of the K/10's or K/20's had two piece shafts. Both my 72 C/10's have the two piece shafts with the tear drop carrier bearings. Something I didn't realize until last Thursday is, those tear drop or light duty carrier bearings are mounted in rubber designed to move forward and backward with the vertical movement of the rear axle. I was going to have the driveshaft shop install a $108 dollar billet aluminum carrier bearing and the tech said that would be fine but a slip joint would have to be installed in the rear half of the shaft. Those billet carrier bearings are molded in polyurethane that is bonded to the aluminum, they wont give or flex at all which leads to premature wear on the carrier bearing and pinion components.
That two piece shaft Gregski showed has the slip joint already in it. The shaft assembly I took in was out of a 3/4 ton C/20 that had a 400TH Trans and a Dana 60 rear axle, yet it too had the tear drop carrier bearing. It did have a 3-1/2" diameter rear half shaft with a 1310 yoke on the front and a 1350 yoke on the rear. I had to have the front shaft shortened 1", 1350 yokes welded on both shafts and a new bone stock carrier bearing installed so he could balance the whole assembly.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-24-2022, 07:29 AM | #30 |
Mine certainly does have a 2 piece. See my sig for the other particulars.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
06-24-2022, 07:37 AM | #31 |
I've never had a 4wd with a 2pc driveshaft, long, short, 1/2t, 3/4t, 3sp, 4spd, auto
06-24-2022, 08:57 AM | #32 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-24-2022 at 04:50 PM. |
06-24-2022, 10:57 AM | #33 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=656307
06-24-2022, 10:59 AM | #34 |
A driveshaft with a slip joint in the middle is NOT a two piece driveshaft as referred to here. A two piece driveshaft has 3 u-joints and is supported by a carrier bearing in the middle.
06-24-2022, 11:48 AM | #35 |
can someone confirm that indeed the long bed trucks and the short bed trucks that had a two piece drive shaft the longer shaft was the same length, the longer being the one going from the center trailing arm support bracket (where the center bearing mounts to) to the rear axle
I just bought one from supposedly a long bed truck and that section is about a foot too long on my '71 short bed Last edited by Gregski; 06-24-2022 at 12:59 PM. |
06-24-2022, 02:45 PM | #36 | |
Probably a dozen front shaft part numbers, and maybe two dozen rear shaft part numbers. Have you seen the brake charts that I refer to from time to time? There are propshaft charts like that, too. I asked the engineer for a copy of the charts and he said he would supply them, but never came through. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
06-24-2022, 03:50 PM | #37 |
The carrier bearings mount mostly in the same place depending on which of the 3 (more?) styles you get. But rear shafts will be different depending on wheelbase and rear diff. And in the front, it depends on which transmission you have and which engine combination. So as described above, there are lots of combinations of front/rear lengths. And u-joint size for that matter. 1310/1330/1350.
06-24-2022, 10:40 PM | #38 |
Which mine has: 3 u-joints and and a carrier bearing. Please don"t try to tell me what is under my truck. I've had it off and apart for u-joint replacement, all three of them.
06-25-2022, 07:51 AM | #39 |
so you're saying there's a chance, lol
on a serious note I love learning about this stuff even if it costs me a few Benjamins to do so, my mentality is: Education Costs, plus I never had any issues selling used / unwanted drive shafts as our local Pick N Pull gals love to destroy them with their fork lifts as they play junk yard tetris with them cars and trucks |
06-25-2022, 08:07 AM | #40 |
I keep a collection of driveshafts. You can always make them longer or shorter... if you have one
06-25-2022, 09:20 AM | #41 |
06-25-2022, 09:55 AM | #42 |
06-25-2022, 04:51 PM | #43 |
So, just to clarify: my '69 K-10 LWB does indeed have a 2-piece driveshaft, 3 u-joints w/ a carrier bearing in the middle. I can't speak to what any other truck might or might not have, but mine has it. It cannot be said that no 4wd from the era has a 2-pc shaft.
06-25-2022, 09:01 PM | #44 |
Right. I would never say that. I have seen long bed 4wd 67-72s with 2pc driveshaft. Just saying I have owned quite a few and they all had 1pc.
07-03-2022, 12:08 AM | #45 |
so I just picked up another "long bed drive shaft" and this one is too short for my short bed, LOL
note yet the different style center bracket my guess is that the donor truck had a differential with a longer (I think it's called) third member that or maybe the truck had a Dana diff, I think the seller pointed out a bunch of trucks on his lot that actually had Dana rear differentials any thoughts on this folks? |
07-03-2022, 12:31 AM | #46 | |
07-03-2022, 01:34 AM | #47 | |
and here's a pic of what claims to be a Dana 60 on the Internet, note the longer snout |
07-03-2022, 06:55 AM | #48 | |
07-03-2022, 08:57 AM | #49 | |
just uploaded a EV Conversion Drive Shaft Purgatory YouTube video Last edited by Gregski; 07-03-2022 at 12:46 PM. |
07-03-2022, 08:02 PM | #50 | |
