10-08-2014, 09:15 PM | #1 |
Gauges won't light
wiring behind dash is a tangled mess. String of gauge lights not working. Some bulbs are missing will that cause them all not to work?
10-08-2014, 10:45 PM | #2 |
Re: Gauges won't light
Most automotive electrical problems can be traced back to a poor ground connection. I'd start there. Make sure that the gauges are grounded to the panel and that the panel is grounded to the dashboard, etc.
10-09-2014, 12:46 AM | #3 |
Turn the light switch knob all the way counter clockwise and see if maybe the dimmer is down. Sometimes if you wiggle it or turn it back and forth they will light. It could just be the light switch. If a bulb is missing it won't effect the others but you might want to try getting some new bulbs and make sure they are ok. A test light would help.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
10-09-2014, 11:43 AM | #4 |
Thank so much for the help I suspect that my new dash powder coated I will knock off coating around gauges
10-09-2014, 06:28 PM | #5 |
Does anyone have a picture of a light switch shows what color wire operates the gauges I was told grey by a neighbor but there no grey wires on the light switch!
10-09-2014, 08:17 PM | #6 |
http://67-72chevytrucks.com/vboard/s...d.php?t=533489 You might find an answer in thei thread.
10-09-2014, 08:27 PM | #7 | |
A good test light will tell you if you are getting the 12v to the lights. Hugh |
